Exhaust Tip(s)
CanadianNick
4.7 V8
Just a quick question. For the guys with single out exhaust behind the rear wheel. What is the longest length tip that can be ran?
And I said tips because also thinking of splitting off and coming out both rear wheels instead of just one.
auniqueone23
I have a 15” on mine
bassheadhemi
Montreal, Canada
I have the 12" Magnaflow (35236) and this is the max you can install without it sticking out if you use the factory pipe. I've look at 5" tips and it look like you have diesel from the side and just look dumb from the back since you can see the 3" pipe going to 5"
Sent from my SM-N950W using Tapatalk
Administrator
I have a Vibrant 1561
It's 11" long 3.5" in diameter with a 3" inlet. I positioned it as close to stock location and cut off about 5" of the stock exhaust. 6c2049e36e11fe17f495d1fd3e963514.jpg
CanadianNick
CanadianNick
4.7 V8
Thanks for the replies guys.
I already went ahead and ordered 13 inch long and 4 diameter Borla tips.
I guess I should have asked this before ordering. Hopefully they work out
blackbeautyhemi
Lewistown, PA
I have a 3” inlet 4” out x 12” long. Perfect size, 13” should still work fine just not sure how the 15” would tho.145DD1E7-1471-42AB-AC9D-9BAB8814D32A.png
