Bmattei
Dose anyone know what you can expect to pay to have the factory trailer brake controller either installed and programmed or just programmed got a price to day from one dealer of $230 just to program seams very expensive
I bought and installed mine. Took it my dealer and they only charged me $38.00 to add sales code and check that it was working properly.Dose anyone know what you can expect to pay to have the factory trailer brake controller either installed and programmed or just programmed got a price to day from one dealer of $230 just to program seams very expensive
I had the same feelings about mine until I found this setting. Works excellent now. I just towed my 12k+ lbs enclosed hauler over 1100 miles with the gain set on 5 and it worked very well.Do yourself a favor and go aftermarket. The factory controller is garbage. It does not apply enough voltage to the brakes to stop a large trailer properly. Do some research on this forum or google it. There is a large group of people who have actually had their controller unprogrammed and went after market
I love the factory controller. Had sway on my little 4,000 pound single axle travel trailer. I towed the trailer last summer around 8 times, even with sway bar, had sway, to point kind of made me uncomfortable. I was using a p3 controller and worked fine. Then I put in the factory controller, zero sway. I was having a issue with my sway bar making a noise, probably from rust etc . so I temporarily took the sway bar off. Went on trip 160 miles, no sway bar, no sway at all. I know in 2013 they added sway control to the Rams, so is only thing I can think helped the sway. Was windy and in past I never went on trip where I didn't have zero sway. Made me happy.
No, doesn't indicate it, the icon is just showing trailer brake is flashed into evic. But I was surprised the sway control (uses the abs) works without even noticing. My trailer is about 3,400 unloaded and closer to 4,000 on long trips, I went over mountains, with side winds from ocean, zero sway, was very happy. I used a p3 controller for year before I installed the oem one, instantly noticed the sway was gone with everything being equal. Installing the used controller module and switch was easy, hard to get to module screws but otherwise was simple. Then just flash was needed from dealer.Is that little icon in the EVIC for the brake controller actually a sway indicator? I'd like to know I had some sway control on my little 3000lb travel trailer.
I have one in my '10.So, I can get an OEM controller and not get it programmed into an '09?
I agree, very little information out there. I will have more time to test it this summer, but last year towed same trailer with same hitch and sway bar. Took trailer out a lot, like 1-2 times a month, anytime I went out there was a sway even with the sway bar attached, but was acceptable. A few times I was only going maybe 10 miles and didn't connect sway bar and had to keep my speeds down and obvious sway. First trip after the factory controller I went to Oregon from WA, along the Pacific coast with side winds and no sway, didn't think that was even possible for it to totally go away and only reason I didn't have sway bar on was as I was leaving camp ground, was making a noise, needed grease. So removed it until I could find good place to stop and grease the sway bar ends, then noticed wasn't needed for first time.That's very interesting. It's hard to find information about exactly how this system works. The owners manual just mentions that it works with the stability control system. From what I'd read in forums (RAM, Ford and Chevy all have this now) the system does nothing unless you get into a really hairy situation with sway getting out of control, at which point it will engage to cut engine power and apply brakes left/right to truck and to trailer as it deems appropriate to get you back in line (i.e. not flipped over in a ditch).
If the system is more active that seems even better. If it's constantly doing some light trailer braking with no indication that it's doing so however, it seems that would add wear to the trailer brakes and mask a problem that you might want to know about (such as an uneven load in the trailer).
