So i finally lowered my truck after 14+ months.... Bought the belltech 964sp and got it installed yesterday the kit came with 4 springs 4 shocks 4 bump stops short rear swaybar end links and track bar relocator...my only concern is that the guy did not cut the front bump stops cups. Is it necessary to cut them off?
If you are going to pull it apart and cut the cups off, put your original R/T front shocks back in. It will ride much better and not "float" as much as it does with the BT shocks.
David
Looks killer lowered. I wonder how wide of a wheel/tire can fit on the back of one of these?
Thanks for all the great comments...next might be tinted tails and third brake lights or maybe powder coat the wheels...im still sceptical about the wheels though.
There is enough room to fit a 12" wheel, but you are limited by tires. Basically, a 305/40/22 is the widest tire available that is the right height. They say that it will fit on a 12" wheel, but I am not sure if it would look right. It may pull the tire out. ???
David
Thanks guys!....and the ride its a little bouncy/stiffer but over all great.
He would have to go with a lower profile tire which would mean lowered more with a speedo recalibration by whatever means .Would love to see one of these with some 345's out back on a 20 inch wheel.
Drop it 2+ more, problem solved.Unfortuantely the 345 tires are only 28" tall, we need a tire at least 30" tall or it will look like a rubber band, IMO.
David
