Finally modding!
dodge dude94
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Thank you and I shall.
Good luck with your bumper cover.
dodge dude94
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
That this is downright spiffy compared to mine. lol
dodge dude94
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Not that long because the truck I pulled it from was up toward the front. No air cleaner, yes. Fuel rail and injectors were gone and the TB was unbolted. Only had to take the connectors and 3 bolts off for the cables tho. :D
crazzywolfie
under the truck
someone must have been driving that truck up and down some dirt roads with the filter off.
dodge dude94
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
It was oily as hell and was next to the dirt road running through the lot, so I'd say that's the cause. I'm telling ya, it was never serviced and the plenum was bad blown.
crazzywolfie
under the truck
that might explain it. i got mine fresh off the engine. the jeep ran up till the point i took the the TB and 120A alt.
dodge dude94
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Yup. I could have gotten a tb that was cleaner, but all those had corrosion on the aluminum. SO I took the greasy one. :D
WhiteExpress
Midland, TX
Did you get the screw out yet?
Take it to a machine shop, spend the $40 and have them remove it.
They should be able to get it done speedy quick.
Merc225hp
NA
truck
gas
The screws that hold the butterfly in place are not meant to be removed and reused. In some cases they are peened over on one end so they can't back out. Don't try and back it out run it through the hole. Use a small bit and drill it out and hope it comes out, then go find new screws.
kpd12
5.9 Magnum
Yeah did you get it out? I was able to get 3 of them to come out without issue, then wham! Lol.... Guess I'll be trying the small bit myself...
dodge dude94
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Nope. I don't even know where the machine shops are. lol
GAH!! WTF! I reused the ones on mine just fine. :banghead: *sigh* Alrighty then. Guess that changes things a tad.
Not yet, need to go to the store to get bits. This is weird that we're both having this issue. :wtf:
Merc225hp
NA
truck
gas
Its not weird at all, as I said the screws are not meant to be messed with. This is very common on all carbs, tb's not just trucks and cars.
dodge dude94
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
What I don't get is how you're supposed to give it a good cleaning. I mean, sure you can get brake cleaner in there to blast most of it away but there is always some gunk right at the throttle plates that's a problem.
Merc225hp
NA
truck
gas
Its called a carb cleaning tank, you soak the whole thing, using a can of spray CARB cleaner is a waste of time and cash. Brake cleaner should not be used on carbs/tb's.
kpd12
5.9 Magnum
Yeah I knew they could be an issue and knew they were usually pressed at the end to keep them from backing out, I guess... Hoped they wouldn't give me trouble though... I've tried drilling it some, but they are pretty hard and my bits aren't making much progress... May try to machine shop route so I don't mess anything up
dodge dude94
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
:banghead: Well...the more you know I guess...
Damn. Well, I'll let you proceed for now to see what becomes of it. I was likely going to get a screw extractor kit to see if that would do it.
kpd12
5.9 Magnum
I'm gonna check with a buddy to see if he has a screw extractor kit with a small enough extractor and if not look into the machine shop option... I'll keep ya posted
Merc225hp
NA
truck
gas
A good drill bit should eat through those like butter, try a sharper or new bit.
