Floor Console Squeak Issue
Odin
Arizona aka HELL
Hemi 6.4L
I've got a 2015 2500 4x4 Tradesman which I've had for over a year now. Within the last month I've started noticing a squeak, like plastic on plastic, which I think might be from the floor console area. It happens when accelerating, braking, or going over bumps.
I was curious if anyone has had this issue and if so what you did to solve the problem? I've tried pressing on the console, hitting it, etc while I hear the squeaking noise but it doesn't help.
stoney
Ontario
2015 | 2500 SLT CC
6.4L w/ 4:10
My center console squeaked last year, annoyed the hell out of me, it was one of the compartment doors, the locking mechanism and not the hinge (do not recall which compartment right now - upper or lower)....I added some lubricant to them & shimmed the latch, did both at the same time, so not 100% sure which one fixed the squeak, I am thinking the lubricant though.
The squeak only started when the cold weather set in last Fall....it was fine all Summer.
PippinAin'tEasy
Manual 4wd by chance?
"Oh, sweet debt. Thy name is Truck."
PippinAin'tEasy
If yer squeak sounds like styrofoam food containers rubbing together it could be the 4wd shifter rubbing. Mine was/is. This motor's torque-y as all hell and I was surprised at how much it moved around. I just nudge it to the side a little when it acts up and that usually gets me through the drive.
Odin
Odin
Arizona aka HELL
Hemi 6.4L
That's exactly what it sounds like. I'll try that on my ride home tonight, hopefully it solves the problem.
River19
"Live" VT, Work in MA/RI
Hemi 6.4L
My Longhorn has the squeaking in the cold weather as well.....I will try the "lube the hinges" theory at some point. By the time I have had it with the squeak it is usually Spring and the warm weather seems to stop it.....
Odin
Odin
Arizona aka HELL
Hemi 6.4L
Reporting back...
So far it hasn't done it. However, I had to take a different approach. I tried just moving the 4wd shifter and that lasted a whole 10 minutes. I had to actually shift the shifter for it to stop. Did that Sunday morning and so far I havent had any issues!
Orca
