Fording Depth on a 2015 Ram 1500?
rvaj
Supercharged 6.2L
Does anyone know the safe fording depth on a 2015 Ram 1500 quad cab with a leveling kit? I am in an area where I am forced to go through standing water and I need to know what I can do safely. I have seen the TRX rated at 32", and some Jeeps at 30" stock, but I can't find anything on my truck. If you could point me in the right direction I'd appreciate it.
kurek
Northwest
The owners' manual on my 2015 Ram 1500 4x4 states that you shouldn't drive through water deeper than the height of your tire sidewalls:
We all know that's some **** but it's the official statement about the vehicle from the manufacturer.
I don't know what the real limit is, I'd feel comfortable at 2 feet personally. Remember that technique is as important as measurement - if what you're doing would look awesome on the cover of a magazine it's probably the dumbest possible thing you could be doing, a good water crossing will look pretty boring.
indept
South Jersey
If you go in deeper than axle height you better plan on draining and flushing those differentials. Water trapped in axle housings cause bad things to happen.
I never bothered looking under my truck but my old Jeep Grand Cherokee had vent hoses that were mounted higher up on the frame. Thats where water would get into the diffs.
rvaj
rvaj
Supercharged 6.2L
Thanks, this is all good info. I'm a little surprised the warning in the owner's manual is so lame. If you can't drive it through more than a couple of inches of water, it's not a truck, it is a toy. This will give you an idea of what I need to be prepared to drive through from time to time. The Fords, Chevys, and Jeeps weren't having any problems.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Ideally, yes, and I was aware, but i wouldn't bank on it or risk it unless your sure...and the clamps holding those hoses on are tight.
I've seen it happen even with the diff vent hoses mounted up higher. Water still got in.
Those trucks also had big lift kits and big tires on them. Much more so than just a leveling kit. You may wind up with water in the cab.
I would not attempt that in my stock height, stock tire 2500, but that's just me.
Could I make it? Probably, but it'd be sketchy and my 2500 is significantly taller than a 1500
Just my thoughts. Please post a video if you go for it. Good luck.
ram1500rsm
Trabuco Canyon, CA
Manual, what manual? Lol.
Op, know where your diff breathers are, trans/tc breathers etc. They should be higher than your door seams if they arent relocate them higher. Super easy to do with fuel or trans hose and couple of plastic fittings if it was needed. Little bigger tires help too. The stock 1500 application is hindered by the front bumper and car like tire thread and sidewalls + factory heigth suspension. Get a little lift, some 35's, high clearance bumper and you will surprised how many places you can go with the truck.
rvaj
rvaj
Supercharged 6.2L
Thanks. It's taller than stock with Falken 285/65/20s and Bilstein 5100s. Made it through with no problems but I need to do it again this weekend:
rvaj
rvaj
Supercharged 6.2L
Thanks. It's a couple inches higher than stock with 285/65/20s, Bilstein 5100s. I'll take a look at the breathers.
Danny Phillips
Payson AZ
I'd like to find out the same info on my 2015 2500 Cummins. I did the vents for the auto trans, front and rear diffs I never got to the transfer case.
pacofortacos
It's probably because people die trying to go through water deeper than that.
There's a lot of stupid people out there that try driving through flooded areas and die every year. So, to cover their behind they state the sidewall rule as max depth.
Six inches of water will reach the bottom of most passenger cars causing loss of control and possible stalling.
* A foot of water will float many vehicles.
* Two feet of rushing water can carry away most vehicles including sport utility vehicles (SUV’s) and pick-ups.
caulk04
I was just under my truck the other day for something and I think I was looking at the front axle vent and was surprised how low it was.
Bottom line, just check your fluids if you're suspect of anything. Find water? Extend the vent and repeat.
PolarisCobra
Mendon, MA
You may well get through, and you may think that you have no problems. In a month or two, you will know if water got into any of the driveline parts where it doesn't belong. That's when the fun starts.
Tray Burge
On the porch
Tell that to the Jeepers that find out too late why they need their axles 100% water sealed, think they call it "milkshake." lol
kurek
Northwest
Wouldn't want your axles sealed. When you dunk a hot axle in cold water the air inside it shrinks and it's going to draw in water past the oil seals. Raise the vents above the anticipated water line for best outcome, or go a step further and pressurize your gearboxes like military and commercial vehicles whose intended operation includes submersion.
Dean2
Near Edmonton
Best advice on this thread. If you regularly want to ford deeper water, then there are a number of steps you need to take to prepare, and you need to do at least weekly maintenance in terms of checking diffs, transmission, transfer case etc to offset that type of use. Pickups were not made to do water crossing above the bottom of the Diff, as a regualr or routine useage.
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
There are many vehicles out there designed for this type of severe abuse. Our 1500'a aint one of them if you want to play U-boat Commander. Aside from the differentials taking on water, just think of all the electrical connections at that level, too.
Jeepwalker
WI
2012 Reg Cab, 4x4
I'd be more worried about wheel hub/bearing assemblies and front diff intermediate shaft (and bearings) taking on water ....and fine silt (which usually comes with flooded or flowing water). And water which gets into the 'pumpkin' is going to turn to a foamy milkshake as mentioned above.
If ya let it sit over a long weekend it should settle out and a guy can often drain most of the settled water out of the vehicles that have bottom drain plugs (like Toyotas) and I some front diffs. Or take a suction gun with a small flexible hose and draw off the diff bottom. Ya probably won't get it all though.
