Front driver's seat bottom separating
gto64gto
Tbor City NC
On 3-25, I posted information about my front drivers seat separating. I have taken it in to the dealer and he has removed the seat bottom. This is what he found. There are 4 seams that run from left to right on the seat cover between the thigh supports and front edge of the seat. The 1st and 4th seams have provisions under the seat to run a nylon line through the seam from left to right that holds the cover to the cushion. the 2nd and 3rd seam does not have this provision to hold the seat cover to the seat cushion. This is what's causing the seat cover to separate. I don't know what Chrysler is going to do. The service rep said they consider it normal wear and tear. I told him (we're friends) that was BS. The truck stickerd over $50 grand, It's a year and a half old, and I have a life time warranty on it. He said he is going to contact his factory rep to try to get it resolved. I've talked with a Ram Care Specialist and they have contacted the dealer and are staying in touch. I'll let you know what the outcome is when something is settled. I told the Ram Specialist that if that's the problem, then Ram should run nylon line through all of the seams. That would solve that problem. The passenger seat has not done this. I hope none of you haven't had this problem.
