Full exhaust or just muffler change
2batruck
I currently have the 22 inch magma flow muffler. Just took of the stock exhaust off and put this guy on. Loving the sound. I have a bit of cash on the side and wondering if there is any benefit to putting on the magma flow full exhaust system?
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
The Magnaflow catback actually uses the exact same muffler you already have. I would slap a set of longtubes on there like mentioned above.
Statcher1
Kentucky
Yep that's the next step. A cat back is basically the same thing your running right now. If you have the factory dual exhaust.
2batruck
2batruck
Thanks for the input. I've looked at jba shorties but not worth the money for minimal performance. I don't want to spend money on longtubes. How about a ported throttle body from moe's performance?
hdwrenchtx
TX
I went with the flowmaster outlaw direct fit muffler...happy with it. I'm also interested in the ported TB.
jlpowell84
Well I just had my American Racing long tubes with their Ypipe and high flow cats installed by my muffler shop. Now I am installing a full MBRP cat back, worked on it last night and am about to go out and finish. Had a tough angle to deal with so it has taken some extra time. Anyways it simply looks amazing under there with all brand new stainless pipes. I bought a 2012 used with 65k and the muffler looked like it had some spots that could have been a problem in 2-3 years, pipes seemed a bit beefier. But I can rest assure no section will need replacing :)
BlkExpress15
3.6L
Have another exhaust question. I have a 2015 that has the 2 muffler set up (large one just after the cats, and another small one right before the tip.) Question is, what would be the result if I removed the larger muffler, and kept the smaller one before the tip?
Orca
