Gear Ratios
01bigblue
Georgia
5.9L
I've got 36'' toyo's on my truck. Any suggestions on gear ratios should I change them? What will they do? How much does that usually cost?
Johnn123
Ontario
Well what do you have for a truck? Depends on your config. If cummins, it doesnt matter. Gas I wouldnt go higher then 4.56.. If its a half ton Id look at getting some Dana 60 axles, D44 sucks and chews through front end parts on bigger tires. Steering really isnt the best for big tires either.
01bigblue
Georgia
5.9L
Okay it's a 2001 ram 1500 with the 5.9. So everybody thinks 4.56?
Merc225hp
NA
truck
gas
Depends on how you use your truck in my op, but 4.56 or 4.88. Gear sets run about $300 for each set, plus any install parts like bearings and shims (major kits run about $200 each), then there is labour for the install 4hrs for the front and 2-3 for the back. For the front you can go with thick cut gears or you will need a new carrier for the new gear ratio. For the rear there is no need for a new carrier or thick cut gears as the 9.25 has no break point. So about $1500-$3000 for all the parts and work.
01bigblue
Georgia
5.9L
Oh wow, that's a bit more than I was expecting. I just sunk $2500 in tires wheels and bull bar. So that might be a bit down the road I appreciate it!
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Still cheaper than a new trans in most cases.
01bigblue
Georgia
5.9L
That's true is that what I'm looking at if I don't change it soon?
EM2(SW)
Norfolk, VA
I just put 4.56s in my truck and it was worth every penny. Feels like i have power again ;)
Johnn123
Ontario
I wouldnt worry about mileage in one of these trucks, shouldnt of bought one if you were lol. They are NOT fuel friendly in anyway!
Your drive train will taxed more then it was ever meant to be and eventually grenade itself, leaving you either needing a complete rear end rebuild or trans rebuild, possibly more. Big tires on stock 3.55 in a Dana44 is just a plain bad idea.
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
Around what RPM is your truck at on the highway around 70 mph.
And to the original question its really a personal preference. I think I'm going to run 4.11s on mine. I have 37s on my 1500 5.9. I don't like the idea of going too high (or low depending on how you look at it) because of RPM at highway speed.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
*cough*dog*cough* *cough*4.56*cough*
Excuse me, I see to have allergies bothering me. :naughty:
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
Those ratios are too high for me personally for highway. And D60s, well I honestly dont feel like it's a necessity. I want to finish with the truck so I can put money into the Nova again
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
37s on 4.88s is like 35s on 4.56s and 33s on 4.10s. Which are all like 31s on 3.55s.
Only running 4.10s on 37s will cook your transmission and will lug your engine bad, making your gas mileage worse.
Orca
