Gearing a 14' for 37's
deangtp
I have a 2014 ram 1500. I put on a 6" lift and 1.5 body lift. I have 20" rims. Looking to go 37's. It has the 3.21 gears, but was contemplating getting a 3.92 front carrier. You can get a stock unit for 500 or less. It's a quick swap. The rear would be setup by a shop with an lsd installed with the new 3.90 gear. Would this be ok? Is there any difference in axles splines between the two stock gear ratios? I have the 8 speed.
Ram444
Cummins 6.7
3.92 will be better than your OE but like ^ said a 4.56 would be best.
mselph544
Louisiana
Dumb question. But what would the higher gear ratio help? I have 3.21 with 37s currently.
Ram444
Cummins 6.7
The higher numbered rear gear ratio the lower it's geared. This helps keep your truck in the highest power band more frequently. It will vastly improve 0-60 times, pulling efficiency and basically limit how much of a dog your current trucks performance is. Put your stock tires back on and see how much better your truck performs. The higher gear ratio corrects the oversized tires by putting you back in the factory power band designed for your transmission.
mselph544
Louisiana
But gearing my truck higher should reduce strain on trans?
Ram444
Cummins 6.7
I guess it would promote useage of all your gears rather than just the first few.
Kid's HEMI! !!
I have 7" lift 35s with 3.21 . I put hemi fever tune it moves just fine mpg is good to get about 20 mpg at 80
satxwy
Pentastar 3.6
But would you really need 4.56 with the tall gearing internal to the 8 speed trans?
kg93
AZ
with the 8 speed 3.92 would work, 4.10 would bet better, 4.56 would be awesome. With 37s im talking.
6.7CumminsDrvr
The Dude abides………
Georgia
Around town, not so much but once you get into the overdrive gears you would. The 8 speed and 5/6 speed have the same top gear of 0.67 so once up to speed and cruising the 8 speed has no gearing advantage.
Rken1288
That's almost as good as a stock ecodiesel. Impressive....
D
deangtp
I thought about rehearing to 4.11's, but figured the 3.92's would work. It's more money and perhaps more down time. There was a math equation that shows
33/33= 1 X 3.21 (Stock setup)
33/37=.89189 X 3.21 would net me 2.86 (37'sw/ Stock gears)
33/37 = .89189 X 3.92 would net me 3.49 so that's what makes me think 3.92's should be fine.
Does the math work out. Am I correct in my thinking? I don't hate the 3.21's. I know the 4.11 or 4.56 would make it feel more peppy, but is it totally necessary?
Dmopar74
Geeze and here I am worried about going from 33s to 35s with my 3.73 gears behind my 6.4.
Dmopar74
The site I used said you would need a 3.59 to equal stock, but I have no first hand experience to say the 3.92 would work well or not, I would assume so.
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
I have 3.21s with the 8 speed and stock size tires and I never get 20 mpg at 80. On the highway our speed limit is 70 so I set it on cruise at 75-80 and on the evic it shows around 18.5 usually. 19 would be on the high side. I'm sure if i hand calculated it it would be worse. How are you guys and gals getting such good mileage even with bigger tires? I'd like to know your secrets.
