Going from steel rims to aluminum.
ranchhopper
illinois
I am going from OEM steel wheels on my tradesman 2500 to a set of OEM aluminum wheels will I have to change out the original studs for longer ones?
CanuckRam1313
Ontario Canada
2023 Warlock SLT
Nope, they are all the same. You may need the appropriate lug nuts that go with the wheels though
Exactly!
Very important to get the correct lug nuts for the rim application.
And, ensure you retorque after 100miles.... I believe it's 130ft/lb.
ranchhopper
ranchhopper
illinois
Im going to check the lug nut differences out and order what I need if need be right now I wanted to make sure the studs didnt have to be changed out.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
found this online, so do further checking
What lug nuts to use with aluminum wheels?
An ET Style lug nut has a 60° conical seat and a small extended shank to allow for more thread engagement. This type of lug nut is commonly used when putting new, aluminum wheels on older vehicles that came with shorter wheel studs. Jun 12, 2018
