Good deal?
Jimmy68
Lethbridge Alberta Canada
5.2L Magnum
I found Front is a Dana 60 with 1.5 ".250wall tie rod and draglink with offset GM 1ton taper tie rod ends and a north west fab freddilink above knuckle, trackbar mount has a weld washer to eliminate ovalizing the hole, has bds lift brackets, extended brake lines, brakes are 85%, CAD unit is permanently engaged, and the Pitman arm for the different taper tie rod end. Bds control arms.
Rear is a Dana 70 with posi, good working drums, 1410 yoke. Also have a 14bff with disc brakes in the deal.
All diffs are 4:10 all work good and a 6" BDS suspension lift.
$1400. Good deal or what?
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
$1400 seems good to me as well, but I'd still try to be on the cheap and offer $900 if they take it, hey you saved $500. I'd only make that offer in person after checking everything out and then pull out the cash and say well I've got this, want to help me load it or what?
Have had many good deals that way.
Jimmy68
Jimmy68
5.2L Magnum
Today I do not have the money to make that deal. However, if I give him a deposit he will hold it for me so I can pay it off in a few months. So I really have no leverage to deal on price.
Jimmy68
Jimmy68
5.2L Magnum
So I looked at it last night. Nice. He's running 38" Boggers on his 94 and a 3" BL.
I have the 3"BL already but only plan on running 35's.
Excited to get it home. Be in March sometime.
Jems007
