Drummin4jc
WWG1WGA!
- Feb 3, 2015
- 2,375
- 1,218
- Location
- SW Pennsylvania
- 2024 Ram 2500 CC
- 6.4 Hemi
Looking good! Can't wait to see the completed pics!
Adam
Adam
Looks good man. Where did you hit the tree at?
Looks great! You're a braver man than I am using the hi-lift, always found it a bit precarious supporting the weight of a vehicle.
I finally got a little time to install the passenger side rock slider yesterday, and the transfer case skid plate today.
Neither the front skid plate nor the transfer case skid plate were listed as fitting a 2014 model year 1500. The front skid plate bolted right in place no issues.
The cross brace for the transfer case skid plate bolted right in, but I had to drill two holes in the skid plate to bolt it onto the cross brace. I simply bolted the front of the skid plate onto the front cross member, then took a marker and marked the location of the cross brace holes onto the skid plate then drilled them out...easy day.
DO you have teh part numbers, for the skid plates that work with a 2014 Ram?
