Halo headlights staying on
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
Hey so I installed some halo headlights in my truck. They work great and look great. My only problem is on my passenger side, the halos will faintly glow even with the lights turned off. I have to disconnect my battery for them to turn off. I have the wires for them spliced into my parking/drl lights. I'm no wiring expert so any help would be appreciated. I attached some pictures of the headlight model and the way I have them wired
BlackMagnum2000
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
Not unless that box in the picture is a capacitor. Besides I figured if it had a capacitor both sides would stay glowing
Stangshcky12
Oshkosh, WI
5.9 Cummins
Could be a current leak on that side so it's getting a little bit of power, since LEDs only use a little bit of current unlike incandescent bulbs it's glowing
A resistor on that side should make it stop
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
Mine did the same thing. Sold em after a week of having them. Bought some stock replacement heads for half the price of those.
BlackMagnum2000
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
Okay so I've done some testing and found out that the halos are getting power from the low beam positive, high beam positive, and the ground for those. Why are all three of those plugs hot even with the lights off? If I can get those to turn off when the lights are off I believe that will solve my issue.
I assumed it had to do with the whole 9004/9007 issue, so I tried completely cutting out the factory and aftermarket wiring harness adapters, and cut and spliced them in manually. Yet it still doesn't work. Getting very frustrated with these. But I absolutely am not going back to the original headlights. I'm too sold on the look of these halos
Dodge96Ram
Long Island NY
Magnum 5.2
You have voltage leak for lack of better terms. It's not enough to light up a stock bulb but it take next to nothing to make an LED glow. All you need to do is wire a relay in to isolate the halo from the parking light wire. Pretty much you use the parking light + wire to trigger a relay which turns the light on. The relay is an electronic switch and when it is not energized, it isolates the 2 circuits from one another.
BlackMagnum2000
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
If that voltage leak is going through the headlight bulb, would it just go around a relay?
Sorry if this a dumb question, I really hate wiring and electronics. Just not my thing
Dodge96Ram
Long Island NY
Magnum 5.2
Not dumb at all, we all learn by asking questions. Im certified in 12V electronics, i sleep eat and drink it lol. Anyway here's what you do. Get 2 relays and wire them both exactly the same. One for each light .
Pin 86 and 87 both go to the 12V+ parking light wire
Pin 85 goes to ground
Pin 30 goes to the halo 12V+ wire
Give it a shot and report back.
Stangshcky12
Oshkosh, WI
5.9 Cummins
or you could just put a resistor in that will take the small amount of current instead of the LED
Stangshcky12
Oshkosh, WI
5.9 Cummins
From the picture you posted of where you spliced in I didn't see one in that wiring
Frankly in most cases it should not have or need one
More expensive lights will have a LED driver for the halos that supply a constant current and voltage to help extend the life of the LED
As far as I know these do not, they are just a straight wire to the LED with know added resistance.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Did you seriously splice that **** together with masking tape?
Stangshcky12
Oshkosh, WI
5.9 Cummins
I think (hope) its white electrical tape
They do make it, I know harbor freight sells packs of colored electrical tape
Dodge96Ram
Long Island NY
Magnum 5.2
The colored tape they sell is junk. The only tape you should be using is 3M Super33
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Or solder and heat shrink it.....lol I got a heatgun now, so that's what I'll be doing on my splicing projects.
BlackMagnum2000
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
I soldered it and then put electric tape around the solder, and duct tape around the electric tape. And the duct tape just so happened to be white.
What size relays do I need? Size, wattage, etc? Being honest this is the most I've done with wiring lol
Dodge96Ram
Long Island NY
Magnum 5.2
Duct tape doesn't belong on wires, ever. Just go to your local autoparts store and get a standard bosch style relay. You will be pulling next to no current through it.
BlackMagnum2000
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
I figured duct tape over the electrical tape would hold up better against elements, compared to just electrical tape
Orca
