OscartheGrouchh
Replaced the headlight bulbs on my ram today (2010 ram 1500) Only to find out my passenger side wasn’t coming on after I put both new bulbs in. I knew it wasn’t the bulb because I tested it with the driver side and it worked. Found out it was the plug in from the harness (bad ground). I found this out by checking each pin with a test light. The black wire is ground which is in the middle, the other 2 on the side is low and high beam. Anyways Made a ground for it and they are both working now. It will do for now until I have time to buy another plug in from a junk yard or something. But yeah. A bad ground will make you scratch your head more than once.
