Heads up--cabin air filter
GIJoe2010
No sh*t, there I was . . .
Killeen, TX
Mine's a 14 1500 and I too had to cut for the door and filter.
'11
6.7L ISB
Does anyone have any issue with the door not fitting snug and whistling at high speed? I'm using the k&n filter.
Sent from my SM-N950U using Tapatalk
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
From what I have read the door is not fully seated ! It can be a pain,. If I remember right try hooking one side first then snap in the free side!. Did you cut the opening ? If so did you notch the lower cut out area ?
KA1OTE
Ram Ham
Riverside, WY
2012 Ram 1500 Laramie CC
5.7L Hemi V8 390hp 407lb/ft
I did this mod as well and can say that the door/panel can be a pain to re-seat after a filter recharge (I use the K&N oiled version).
My advice and what I have figured out works, at least for me and the Falcon... when putting the door back on, hook the driver's side first, then press on the passenger side, gently increasing pressure until you feel it click/snap into place. You will feel it, but may not always hear it.
'11
6.7L ISB
I cut it myself. Pretty sure I cut the notch. I'll try reseating it tomorrow at work and see if your suggestions help! I have the oiled k&n as well
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
xxxxxx
I did when first installed. Waited for a very hot day when plastic was pliable and got a good seal. Problem hasn't reoccurredd with subsequent filter changes.
Chickamauga, GA
I did mine with a utility knife, PITA. But I took my time and did it right, seems to work rather well too. The dust that used to show on the dash is nowhere like it used to be, no whistling. I think I used a Chrysler 200 cabin filter for the application. I also pulled the blower motor and cleaned it out after install. It’s worth it! I am not sure when to change the filter. I’ve gone about 15,000 miles so far.
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
I have a 2015, SO pulling the blower motor is fairly easy ? Thanks
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
Extremely easy. I think 2 or 3 fasteners and it comes down! You can see them if you look under the dash after you remove the glove box.
Thanks for the info. When our temps get above 11* Ill have to look lol. Which would be spring and It should be time to change the CAF so that will be a good time to look and yard it out ! That does sound like something I could do :) Thanks for the info
craigsez
Novascotia,Canada
How tight of a space is it for the caf??
Forgot my phone home to search the # for the fram fb filter..Looked in the book at wally world and nothin was listed so i grabbed the v6 from 2015...Compareing the 10729 vs the b6 version from 15 which is 10743 the 43 is .193" longer .0161 " wider and 10729 is taller by .08" .....Hopeing it will fit and save me a 20 min dr to wally world..
madtrucker2016
New York
Hows about Brought a filter kit for my 2016 Laramie from Genos garage and went to install it.. Took down glove box and **** the cover was already on the truck so I said not bad I,ll just change the filter now,and have a spare cover for the air box. When I finally got it opened Their was no filter on my truck from the factory they robbed me of a cabin filter on a 56,000 truck. Ram if your reading this Mail me a new Mopar cabin filter
buddy guy
alberta
if it makes you feel better, seems this was standard practice until 2017 i think someone mentioned before. it was cheap ass, but they were doing it to everyone!
misfit77
old news but for you guys, per FRAM
CF11671
Length 8.53
Width 7.762
Height 0.985
CF10729
Length 8.51
Width 7.644
Height 1.005
TonyMM
2016 RAM 1500 CC 6"4 4X4
CF11671
Length 8.53
Width 7.762
Height 0.985
CF10729
Length 8.51
Width 7.644
Height 1.005
So which one is a better fit?
Fitz-0518
Veteran 66-68
Central California
2018 2500. 2018 1500
For our 2018 2500 SLT QC and and our 2018 1500 Tradesman. I found the Mopar filters were a poor fit and made cheap, but expensive. I now use the Fram charcoal and baking soda filter. Get them from Amazon. Last couple were on sale for about $10 each. Fit very snug and highly effective. Fitz
jovtra
