Heat is 1/2 hot
BAMA BOY
Gasden,Alabama
4.7 Liters of fire breathing fury!
Passenger side is hot drivers is ice cold only when at low rpms any ideas
Trupiano
Registered User
Hometown : Puyallup,WA Stationed : Little Rock,
2010 Ram 2500 6.7L CTD Crew Cab
6.7L CTD
Sounds like a blend door isn't opening, or isn't working correctly. Just found this on a quick search. See if there's any info to help you out. Sounds like the exact same problem. http://marylandcreepers.com/showthread.php?6222-3rd-Gen-Dodge-Ram-Blend-Door-Issues
I know this is an infamous problem on 3rd gen rams. There's like a little plastic piece that's easy to break, and once it does the door can't operate correctly.
BAMA BOY
BAMA BOY
Gasden,Alabama
Thanks man my whole AC system is **** anyway
The Assassin
B-more careful, Murderland
Damnit, I was late to post lol. I agree on the blend door! Also do a search on here...as well as Youtube. There is a lot of good step by steps out there.
BAMA BOY
BAMA BOY
Gasden,Alabama
I needs blower motor also mine has seen its better days
bigbadram1500
Springfield, IL
I've had the blend door break on both of my rams, but it was the opposite, the passenger side was cold and the driver side warm. Is it also blowing out the defrost vents no matter what the dial is on?
Trupiano
Registered User
6.7L CTD
Just do a bunch of research, order the parts you need, get a couple buddies to help and supply the beers, and you should have the blend door and blower motor knocked out in 1/2 a day!
rambob
LA/MS
318 5.2l
wtf is dodge's problem with a/c and heat systems? have they ever figured it out?
quietpeen
2021 TRX
Hellcat
probably cheaper for them to fix the few that go out under warranty then design a new system.
Orca
