Mallardsx2
- Joined
- Jun 5, 2012
- Posts
- 44
- Reaction score
- 3
- Ram Year
- 2016
- Engine
- Cummins 6.7
Did you ever get to the bottom of this issue? I am having heat troubles in my 2016 as well. Luke warm air is all I am getting.
See this is older but I too am having the same issues. 2014 3500 with 247,000 miles blowing cold air on drivers side and luke warm on passenger. Last year I flushed heater core and seemed like I gained a little heat. Today was 0 degrees on my way to work and think I may need to work on this sooner rather than later.
Is everyone on here thinking it is the heater core? If so I think I'll dive into it soon and just bite the bullet doing it myself. I found a GREAT video that makes it look pretty easy on YouTube that I'll link below.
I’ll echo that backflushing is rarely successful. However if you have a power flusher you have a better chance. With a power flusher your sending water and compressed air in the heater core at the same time.
This may work for some but lemme tell you lol idk what is up with the heater cores on the 4th gens but I have hooked up a god dam power washer !!! to my last one ofc way to much pressure as a last ditch effort before I tore it out as I had nothing to lose didnt do ****. Only thing i can think of is maybe the passage ways collapse inside over time?
Just replace the heater core its the only way its not that bad of a job people make it sound worse then it is. I have done 6 of them now getting good at it lmfaooo it can be done in one day for sure a lot of vids on YouTube to help you. One thing I will say you don't need to remove steering Column just drop it down and don't forget to remove the brake switch I break it every time.I flushed and back-flushed with CLR and radiator cleaner. Left it sit overnight 2 times with CLR in the heater-core. Still no luck.
I guess I am going to have to bite the bullet and replace the whole shooting match.
Any other suggestions from anyone?
