Heater to cold switch is stuck 1987 w1500
Discussion in 'Interior' started by bozeblake, Jan 6, 2017.
  1. bozeblake
    bozeblake Member
    48
    59
    Jan 1, 2017
    Ram Year:
    1987
    Engine:
    318
    The heater control is stuck on cold. Does anyone know what is going on here?
    Sent from my XT1585 using Tapatalk
  2. crazzywolfie
    crazzywolfie Senior Member
    14,168
    2,154
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    does the truck have a/c? usually you can flip down the glove box and access the heater control lever on the heater box. if it is stuck then it might be a bit tough to move it with a set of small locking pliers but it will start moving pretty good eventually. if you ever clean the box out you can clean and grease all the moving parts and make it move real smoothly.
  3. bozeblake
    bozeblake Member
    48
    59
    Jan 1, 2017
    Ram Year:
    1987
    Engine:
    318
    Thanks you are great!
  4. crazzywolfie
    14,168
    2,154
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    no problem. i have already dealt with this issue on my vehicle already so i know what to look for.
  5. bozeblake
    bozeblake Member
    48
    59
    Jan 1, 2017
    Ram Year:
    1987
    Engine:
    318
    On the glove box. do I have to remove the glove box to get to the heater control?
  6. crazzywolfie
    14,168
    2,154
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    no you don't have to. you just have to press down on the center at the back to get it to flip down far enough to get behind the glovebox. you may want to empty your glovebox first tho since there is a possibility of dumping everything on the floor.
    bozeblake likes this.
  7. bozeblake
    bozeblake Member
    48
    59
    Jan 1, 2017
    Ram Year:
    1987
    Engine:
    318
    OK going to try now. I will let you know how it works
  8. bozeblake
    bozeblake Member
    48
    59
    Jan 1, 2017
    Ram Year:
    1987
    Engine:
    318
    Wow so simple it works great thanks again. I just hit it with a little WD 40[​IMG]
  9. crazzywolfie
    14,168
    2,154
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    no problem. i don't know if wd40 is a permanent solution but a guess at least you know where to look if you have any problems in the future.
  10. Sniper X
    Sniper X Senior Member
    50
    113
    10
    Dec 7, 2016
    Ram Year:
    1991
    Engine:
    318
    WD40 is great for getting rusty parts unstuck, but grease it up with a good automotive grease too. The WD40 will dry off and stop providing any lubricity.
Share This Page
