twenty12ram1500
Tech info please HELP!!!
so here are my two problems ....
Problem 1 - the vehicle has no 4 wheel drive, when I switch it in to 4 wheel high or low it shows on the dash going in, I can hear the t-case shifting the solenoid and then wait for it ..... no 4 wheel drive at all, went to dealer they stated it worked on the lift but once on the ground it wouldn't work ??? any thoughts ??
Problem 2 - worling type noise from passenger side front wheel area, ( NO ITS NOT THE HUB, I JUST CHANGED BOTH FRONT HUBS WITH BRAND NEW TIMPKIN HUBS ) sorry for caps lol..... the noise comes in around 20 and stays there .... doesn't change with turning or up or down hill, braking either..... I changed the front diff fluid thinking my diff was blown up but fluid was clean, no metal at all, any thoughts guys ????
