Help bypassing prime gears in shift schedule
bloombloom88
Plano, Texas
Can anybody help explain how I bypass 2nd prime on my shift schedule? I've been playing with it for about a week now but I'm not sure how to make the values lower than 2nd gear so it skips prime on a WOT downshift
If guns kill people, then pencils misspell words, cars make people drive drunk, and spoons make you fat...
Appauldd
2012 Ram Big Horn
What tuner are you using that allows this to be done?
Just curious.
Paul
SilsHemi
You can't bypass prime in any shift schedule. The Superchips advanced trans tuning won't allow it.
Ramunit
Post 2 on this link is mine, didn't feel like writing it out again.
Not sure if it will work on 09's, On my 05, 2P is only used as a highway passing gear so I was able to hide (not delete) the 2P kickdown behind 2nd to fool the tranny into going into 2nd instead of 2P on kickdown. 06+ 2P is used regularly on upshifts and downshifts so not sure if the values will go low enough on 2P but I do recall BigPapa doing this with his 07 Megacab. Hope this helps
SilsHemi
This. ^^^
bloombloom88
bloombloom88
Plano, Texas
When I tried lowering 2p below 2nd it wouldn't let me. I guess I can't do anything about it
Ramunit
By chance, can you post up copy of the shift schedule you are running? You might have to move 2P Upshift values down first, way below 2nd down then try to move 2P down lower. Just an idea.
bloombloom88
bloombloom88
Plano, Texas
Right now, I have it set to the superchips setting.
Here are my 2 and 2p values
These are the factory values
Ramunit
Sorry man, those attachments are "invalid" according to RF. Let me try to come up with a 09 schedule that will work for you, I've helped a few other 09's in the past. Let me ask you this, have you copied or ever used a custom shift schedule off the shift schedule server? If so which one? http://www.mcfail.net/superchips/ (Hope this link doesn't get sequestered like my other one.) I'll be in touch
SilsHemi
Sorry man, those attachments are "invalid" according to RF. Let me try to come up with a 09 schedule that will work for you, I've helped a few other 09's in the past. Let me ask you this, have you copied or ever used a custom shift schedule off the shift schedule server? If so which one? Directory Listing of /superchips/ (Hope this link doesn't get sequestered like my other one.) I'll be in touch
Scott,
He has a 2009 4.7. I'm not sure if there are any on server.
If he can get his TP values to you, I'm sure you can make him a very nice schedule. :)
Sil
bloombloom88
bloombloom88
Plano, Texas
Yes I have, the 2008 is the one I copied and I got as close as I could. Some of the throttle% points are different from mine. The 2010 was nowhere close. I'd like a really quick shift, and at about 50mph at a wot downshift, it seems like it waste time downshifting through gears until it reaches one that gives me get up and go. Is there a way to shorten that process? Maybe to skip one of those gears in the downshift?
SilsHemi
If you're basing it off a 2008 schedule, that's why you're having some issues. TP has to be spot on when creating a schedule. Once you get Scott those values, he'll make you a schedule and you'll see the difference.
bloombloom88
bloombloom88
Plano, Texas
Ill post my shift schedules tonight, trying to do it on my phone will take forever..
bloombloom88
bloombloom88
Plano, Texas
ImageUploadedByTapatalk1363196422.900478.jpgImageUploadedByTapatalk1363196436.288758.jpg
bloombloom88
bloombloom88
Plano, Texas
ImageUploadedByTapatalk1363196463.768953.jpgImageUploadedByTapatalk1363196478.055462.jpg
bloombloom88
bloombloom88
Plano, Texas
ImageUploadedByTapatalk1363196499.296210.jpgImageUploadedByTapatalk1363196512.418564.jpgImageUploadedByTapatalk1363196525.138470.jpgImageUploadedByTapatalk1363196536.738303.jpg
bloombloom88
bloombloom88
Plano, Texas
ImageUploadedByTapatalk1363196559.045596.jpgImageUploadedByTapatalk1363196571.904393.jpgImageUploadedByTapatalk1363196582.947211.jpgImageUploadedByTapatalk1363196595.916606.jpg
bloombloom88
bloombloom88
Plano, Texas
ImageUploadedByTapatalk1363196617.870431.jpgImageUploadedByTapatalk1363196629.189208.jpgImageUploadedByTapatalk1363196641.397285.jpgImageUploadedByTapatalk1363196652.193099.jpg
bloombloom88
bloombloom88
Plano, Texas
ImageUploadedByTapatalk1363196673.942411.jpgImageUploadedByTapatalk1363196697.634820.jpgImageUploadedByTapatalk1363196708.894589.jpg
Idk why this didn't work this morning... Anyways here it is
Ramunit
The values are strangely so different than my buddies 09. Anyway now I have the values I will make you a great shift schedule, just give me a day or two.
