help-flooded my truck
HemiBabe
DFW
I dunno prolly just wanted a few answers and shagged....
We'll be forever wonderin what happened to that poor hemi LOL
DeputyDipShizz
Pennsylvania
Why in the world would you start it BEFORE changing fluids? I understand cranking it over to get water out...But then putting em back in and starting up? Seems to me just cranking with the plugs out won't get ALL of the water out...Id feel much safer changing fluids after shooting the water out...then start it...and change fluids again after that too
-TapATalkAholic-
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Im speaking from personal experience..... its locked bro. I locked up my old furd a couple years ago in a bigass mud/water hole. Needless to say a wave of water OVER the cab is definately no good, lol.
This ^ is why I havent wheeled my Ram hardly, lol.
Edit: What do ya'll mean by cranking the motor over by hand? How would one go about doing that? We tried pulling my truck forward while it was in reverse, I guess to spin it back and pump any water out, but all efforts were to no avail. Yanked the plugs..... they were brown :(
Bear, if you got a crppled motor, it is not a good idea to spin her with the starter or pulling. You don't want to break anything more with a uncontroled spin. Put a socket and bar on the crank bolt and roll it over to see if there is anything broke or bent. Hydrolocked motors oftenr bend the rods.
Jeremy, where are you man, hell it was just a engine, hope you haven't done anything foolish. I hate it when you have to talk them down....
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
With the plugs out these motors are not to bad to roll over with a breaker bar, still takes a good amount of yank though.
4.7Ram5.7Rango
Lynchburg, VA
4.7 Flex
I see, said the blind man (to his deaf wife) :D
For some reason I feel reeeeeeal dumb for not knowing that... lol. Thanks buddy.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Your all good, its a 50/50 shot on being ok or not to do it that way. Sure is alot quicker if nothing is damaged to clear out the cylinders, just make sure ya pull the fuse for the ignition, noting like **** sparking when you dont want it to.
zack
pa
2004.5 packing the smarty
5.9 cummins ho
Hope he didn't get grounded lol dads truck went mudding an I broke it ..... Maybe should be the name of the post
HemiBabe
DFW
OOOO that would be BAD if it wasnt his truck LOL
B
bu2je
sorry been out of town for work. We tryed to turn it over by hand with the plugs out it will not turn not even a little bit. Im thinking some thing bent in side the motor just dont know what. i really screwed up this time
B
bu2je
lol no not daddy's truck im lucky
RubberFrog
Sounds like a bent rod. You can get to it from the pan if it's just a rod. You wouldn't be the first to get lucky that way.
zack
pa
5.9 cummins ho
Well hope for the best for you man good luck ... Let us know how you make out
Redtruck-VA
Virginia
Sorry to hear it won't turn over. Yep, water doesn't compress very well. My guess is a bent rod as well, hope it isn't too bad for you...
B
bu2je
well about to go pull my oil pan lets hope its not to bad in there
HemiBabe
DFW
B
bu2je
what would happen is i left the water in my motor would it rust any thing like my cylinder for like a month i just dont have time do work on it right now
B
bu2je
and what is that rod called under the oil pan thats every ones talking about
cafolta
