Help installing Bilstein 5100s
Bits
Putting together new struts for my truck with 5100s, my oem coils, and new top mounts. Is it normal for the top mounts and coils to sit this cockeyed? Looks kinda sketchy.
rzr6-4
nebraska
Look up inside your strut tower. Idk definitively about the rams but I've seen in some cars where they aren't perfectly perpendicular and when you mount everything you have to make sure to put it in the correct orientation.
Freakydude
ontario canada
Ecodiesel
it may be late to respond to this but when i did mine there was a certain way they went in. it wasn't that much of an angle but there was a bit of one.
B
Bits
Thanks for the replies, forgot to update this thread. As @crazykid1994 told me in another thread, this is apparently normal. Once installing in the truck with the bushing at the top sandwiched against the upper strut mount on the frame, they are perfectly straight and rides great.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Yes and no. Some can get a little wonky by the way the spring is compressed. Once the weight of the truck is on them it won’t effect it as long as the top nut is all the way tight and torqued to 35 ft lbs
The Lowest coil ring should be on the engine side when installed that will make sure your coils are clocked (indexed) properly
Post a picture of how many threads are exposed on the top strut nut
B
Bits
@Quick_Shifter theres a small hole in the lower perch, should that be on the outside (away from engine) or inside (facing engine)? Currently I have it on the inside but now I’m second guessing myself
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Pictures say 1000 words
mrack
Also interested to know this. I have the updated 5100s that come with the lower perch instead of reusing the oem perch. Both the provided perch and the old oem perch have the little hole but it’s not in the same place as you can see
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
The hole is not what gets indexed. A good method to follow is that the lowest part of the spring should face the engine.
