12lowram
Hello all,
Have a 2012 Ram Express with the A-typical 3.55's and open diff and considering getting an LSD and 4.10's. I've researched high and low for R/T rearends and haven't really come back with much. So, what I'm trying to find out exactly is if the links below are the correct parts that I need. I know that I have the ZF rearend and have heard rumors that these parts will work as long as a diff shop trims the inside of the housing????
Auburn Limited Slip Differential for 9.25" Rear
Motive 4.10 Gears for 9.25" Rear
Ultimately I'm trying to do this swap for under $1200 if I can, thus the reason for the Auburn LSD (Cheap but have heard some good things), and the 4.10's from Motive through Moes. I figure labor will probably run close to $400+ so I think I'm in the right ballpark. If anyone else here has swapped over to a limited slip rearend or has used aftermarket gears on the rear carrier, please feel free to chime in, I'm trying to get this done before January if I can. PLEASE HELP!
