Help!
Ohio5pt7
Ohio
About to pull the trigger on a lift. I'm looking at the zone or RC. Basically I want to be bale to left the front 8". I assume that means i need the lift then get bils and set them at 2.1. I want it to sit level when I'm done. Do either of these offer a bigger coil or block that it would level with the bigger lift up front?
BOWERSFJ
Uniontown OH
I don’t think you can use the top spacer that comes with a 6” lift, and Bils at 2.1” ... That’s stacking, and that’s a no-no ... I’m sure somebody else will confirm ... Your best bet to get to 8” would be 6” and a Zone 1.5” body lift
rwhjr
maryland
You can get a zone or a rc 6” lift and run Bils at 2.1.
I think you’d achieve about 7.5” front lift that way without accounting for any tire size increase. If you go to 2.8 on the Bils you’ll get closer to your desired 8” but depending on how things look you might wanna run some UcAs that correct for a little angle at this point.
6” lifts with Bils at 2.1 or 2.8 look great. Then depending on what tires you run you’ll gain some ride height there too.
I run a ProComp 6” lift with Bils at .7 (and Nitto 35s) and my truck sits 7” higher than stock. I also plan on turning my Bils up to 2.1 or 2.8 and it should make it sit 8.5-9” higher than stock I suppose.
JB1
Houston, Texas
Get the zone since they offer 5" rear coils and yes you can add bils at 2.1 with the lift since the spacer provides zero lift, its merely a spacer however you will not use the 5/8" preload spacer. I use to run that with 37's and there are many here running that combination.
Ohio5pt7
Ohio5pt7
Ohio
Thx. How were the angles? Its gonna be a mall crawler but I camp so very mild offroad.
Sent from my SAMSUNG-SM-G891A using Tapatalk all grammar errors brought you by fat fingers and auto correct.
Ohio5pt7
Ohio5pt7
Ohio
Do you have a side pic?
Ohio5pt7
Ohio5pt7
Ohio
Anyone know if the zone will work with rc 3"-6" ucas since I already have them lol
JB1
Houston, Texas
rwhjr
maryland
0E3556F2-395D-48F3-AA07-817D40F77092.jpeg F92115B4-3E23-42C2-90DC-EC76A0E2BD25.jpeg 35B7C645-D153-4C96-840B-0D1ECE6990E5.jpeg
pics hide some of the rake. The reason I’m going to raise the front a bit higher is that in person it just has too much rake still (ProComp does 4.5” rear lift).
Ohio5pt7
Ohio5pt7
Ohio
Ohio5pt7
Ohio5pt7
Ohio
Also I have a 2" rear spacer already would that work with the RC as apposed to the zone with the longer coil?
JB1
Houston, Texas
I think RC uses a top and bottom spacer versus new coils. Maybe you could swap one or the other I dunno.
BOWERSFJ
Uniontown OH
My bad ... Yes, it’s the preload spacer that you don’t use from a 6” kit, if you are going to use Bils ... I didn’t word my response very well
Reactions: JB1
JB1
Houston, Texas
I was gonna say because you have Bils added to your zone lift lol
