Hesitation/Struggle during 1st start up of day...solutions?
UDCentaur
2015 Laramie
New truck - less than 1,500 miles on it...
1st start of the day or after the truck sits for about a half day...the truck has a hesitation/struggle to start. I'm not sure how to describe it, but just takes a few extra seconds to start and it sounds rough. It will start up after pressing the button...but it's slightly embarrassing that a hemi struggles. Every other start during the day/night - it fires up nicely!
I've read some posts on possible solutions such as fuel cleaners, changing spark plugs, etc.
Anyone else have this issue and fixed it?
Any help would be appreciated!
Hemi395
Cape Cod MA
Like a few extra cranks? Mine did this to a point when it had around 1500-2000 miles on it. I bought my truck in March 2013 and it was still cold out. But the time I had 1500 miles on it, it was May and it had warmed up considerably. That's when it started to struggle to start. It did that throughout that summer and by the fall it was starting normally.
Its weird because its been starting fine ever since. Almost brought it to the dealer but it stopped.
Sir John
Buffalo, NY
2016 1500 Rebel "Mopar 16" Special Edition
There's actually a few threads from different forums out there that talk about this very same thing. Mine does it. Watch my video below. Is this what you're talking about? It seems to come and go. Lately, it hasn't really been doing it. I'm sure it will come back eventually.
https://www.youtube.com/watch?v=fusdPxplqDg
ram5.7hemi
N/A
N/A
yep my 2015 big horn does this. got the truck with 7 miles and now have 4k on it... still doest it often... maybe it has something to do with it being new..?
I would run techron and try 91 octane with it and see if it changes at all.
GP4L
Chicagoland
One tiny hiccup from a high powered V-8 is unacceptable?
What about this one...? Unacceptable? https://www.youtube.com/watch?v=bIOXdfY9t8U
OP, if you're really concerned, take it in. It's new, it has a warranty. Sorry, but I'm not seeing a problem. Maybe I've spent too much time around big cam V-8's.
Kotta390
I don't see a problem either. It shakes just a touch but it could be the fuel. I highly doubt it is the engine. Mine starts up perfect everytime.
U
UDCentaur
2015 Laramie
Yeah a few extras seconds...
Yes - exactly like yours on occasions and sometimes worse.
I know it's not a major problem, but I just thought a Hemi wouldn't make such a weak start. Also a newbie to the Ram and this forum...just seeing if I am in the same boat as everyone else:)
Thanks all for the replies!
Sir John
Buffalo, NY
If you're trying to quote me, then no where did I say "unacceptable". I was inquiring about something I noticed as does a lot of people. It's one of the main purposes of these forums.
Oh that's probably the reason. Just too bad ass to notice the little things....lol. Go away.
Sir John
Buffalo, NY
I run 91 octane pure gas. It comes and goes. Lately, it hasn't been doing it. No rhyme or reason as far as I can tell.
U
UDCentaur
2015 Laramie
Sir John,
How many miles do you have on your truck?
U
UDCentaur
2015 Laramie
10,000 miles now - still hesitates/little rough 1st start of the day. Starts right up every other time throughout the day.
The only thing I wondering is I park on a slight incline (rear is slightly higher than front).
Used only 89 so I could try 91 for a tank and see what happens or try techron.
MANual_puller
Shade tree grease monkey
Vinton, Iowa
2011 Moose
5.7L hemi
I think it has something to do with the MDS lifters settling. They need oil pressure to operate. I have yet to hear of this happening with a HD truck with a 5.7 because they do not have MDS.
StoneDude76
West Chester,PA
My truck has started this recently. Over the past three weeks, every time I start it for the first time it struggles to start. It has never done it before and I have owned the truck since new. It had 7 miles on it.
Sent from my XT1080 using Tapatalk
Rustycowl69
2001 ram 3500
V10
If it were a carbureted vehicle, I'd look to bad choke adjustment, bad needle and seat, bad float level. Since it's FI, I'd guess the equivalent, maybe leaky injector (s), flooding some cylinder (s). Maybe if you checked the plugs in the morning, before you start it, you'd find some are wet with fuel. Just spit-balling, here.
MANual_puller
Vinton, Iowa
2011 Moose
5.7L hemi
You mean like a flat lifter not opening up the intake valve until it gets oil pressure after 3 or 4 shots of fuel land on it?
I still believe it has a lot to do with the MDS lifters. They have had some issues with collapsed lifters in hemis that fail to pump up. No surprise that they may weep a little and drain back after sitting.
rblakes1
I have a 2012 2500 with the 5.7 and its been hesitating for a month or so now, I havent had time to look into it yet. Plugs were changed around 96k, Truck has 110k on it now.
Come to think of it, it started not long after the new plugs were put in. I'll have to look into that this weekend
Sent from my GT-N5110 using Tapatalk
Hemipower95
Mine is the same, I bought it new,6 months later it sometimes still delays in the morning
MANual_puller
Vinton, Iowa
2011 Moose
5.7L hemi
Yeah, mds lifters is not your problem lol I've never had this with the '06 or the '11, both 2500. Look at the plugs and see if one cylinder looks different than the rest. Also, did you get coppers or iridium?
