HIDs
tcazes
5.7L
anyone know of a quality kit that doesn't use resistors? im running a 2013 Laramie longhorn with projector housings
I understand ill need a canbus system but man whats the deal with all of the super hot resistors?!
BigDogg795
Ronkonkoma, NY
From my understanding; resistors are required in order to "fool" the system into thinking the bulb isn't burned out. The canbus system still uses a resistor; just different than using a relay kit.
I'm sure JJ will chime in shortly.
adrianp89
Tampa Bay, FL
Just get a kit from Jermey at Retroshop - I have a '13 Laramie - it was plug and play with no issues.
MADDOG
Out Exploring Arizona
Ditto. I got my kit from Jeremy at Retroshop and it works great.
TRXHemi
Sugar Land, TX
I have a 2014. I just used an HID kit with Canbus ballasts.....plug and play and NO issues!
Crashno1
South Florida
2014 R/T
My '14 had HID canbus kit w/ anti flicker and message cancelers, ended up with the Enlight kit. Much brighter and it was plug and play.
T
tcazes
5.7L
yall rock thanks for the fast responses! the enlight kit is out of stock for a few weeks. I checked retroshop kit. probably go that route and do the 35w canbus kit. anyone do the fogs as well? how blindingly bright are they?
T
tcazes
5.7L
Shoot. Don't think I'll be doing that. Maybe I'll go led. I always run with dogs since the stocks aren't bad at all. Thanks for the heads up.
2014moparam
3.6 V6
DDM tuning's 35 watt plus canbus kit was completely plug and play on my ram when i had the quad lights. Now i am running ddm's ultra non-canbus kit, and i have the relay harness from jeremy at retroshop, and also running the tyc projectors as well.
2014moparam
3.6 V6
Here's the output on mine. 55w ddm ultra kit in TYC projectors, 5500k bulbs. Fog lights are the ddm plus canbus with 5000k morimito bulbs.
T
tcazes
5.7L
That is excellent!!!!! I really don't want to pull the headlights apart to change the projectors so I'm just using the factory ones in the mean time. I used to use Ddm 8 years ago. Seems like the website has changed a ton! Great quality back then though
2014moparam
3.6 V6
I personally have never had a problem with any of their products, and i have had a number of their kits on a few different cars.
Stock projectors are OK, its amazing how much better they TYC replicas are over stock though...
T
tcazes
5.7L
Now. 35 orb55 watt. Which to choose... any opinions/pictures?
T
tcazes
5.7L
Oh I love the output of yours
