Hitch mounted Rigid Ignite Backup Lights 20641
JB1
Houston, Texas
Weather was nice this weekend so I had time to install some Rigid Ignite Backup lights I had ordered a while back. They have a diffused flood pattern and are 1000 lumens each. I have them wired to the trailer reverse lights thru a diode so I can also turn them on with my AEV switches if I need too.
https://www.rigidindustries.com/led-lighting/20641
I had an 8" light bar under the bumper hitch which was good but it was a spot beam and I really didn't like the looks of it hanging down plus it was little too bright and shined on my neighbors bedroom windows, they never complained but it bothered me.
View media item 25513
I wanted some auxiliary backup lights, but I wanted them in a location that would be tucked away and not too noticeable when not in use. While searching I found these Rigid Ignite lights and they fit the dimension requirements of what I had in mind.
View media item 25517
View media item 25519
View media item 25514
View media item 25515
View media item 25516
View media item 25518
View media item 25512
View media item 25511
JB1
JB1
Houston, Texas
Lately I have added the rock lights and now these and they use small 22 gauge wires in a black sleeve. Once you cut it to length it can be a pain to try and “skin it back”. Just a tip I found if you cut it a little notch at the top edge you can peel it back like a banana.
Just a tip
firebuff17
Ct
Very very nice! I have been wanting to do similar. I want to put in the flush mount diffused backup lights by rigid (single row/4 LEDs). But something has been stopping me... I don’t know what... maybe the cutting my bumper, maybe the slightly higher price, maybe laziness... I don’t know.
But do those slip right into the holes in the hitch? All you had to do was drill the holes for mounting screws?
G. Mcpherson
Yacolt, Wa.
2023 Ram 2500 CC SB Tradesman
I see another project in the future. Did you drill holes for these and what size?
JB1
JB1
Houston, Texas
Thanks guys, yes you have to drill a 1-3/4" hole, plus two small holes for the #8 mounting bolts. It was kinda tough because that metal is 3/16 to 1/4 thick. It comes with 1/2" long bolts but they weren't quite long enough so I bought some 1" long bolts. Its a nice location for lights but wasn't easy lol
1500canoe
Central Pennsylvania
I want to know how you got a wrench on the nuts of the inside mounting bolt on each side...
G. Mcpherson
Yacolt, Wa.
I have the Curt Hitch adapter for my LED Brake and Back Up Bar. Did you tap the reverse and ground wire for these?
JB1
JB1
Houston, Texas
Haha ya that was a concern, worse case I would have drilled an access hole from the back but luckily I didn’t need too. If you look in the side view photo and look at the nut you’ll see the nut with a star washer. That washer is attached to the nut and when snug it grips and tightened without needing a wrench. Keep in mind this is a #8 screw so we’re talking inch pounds to torque it properly. That said, if I had thought it out more, I could have drilled/tapped the holes since the metal is so thick.
Yes I too have the curt adapter and yes I just tapped into the wires to make it easy but I also have a switch on the AEV pod to allow me to turn them on whenever I want. The diode prevents the power from backfeeding to either +12v source.
MidwestJ
Illinois
What’d you use to cut that metal?
Thank you sir!
JB1
JB1
Houston, Texas
Disregard. I re read and saw you drilled a 1.75” hole.
Reading is fundamental.
That’s actually a really good location, it’s down low and under the bumper so it’s protected, perfect for hooking up a trailer at night or backing into a camping spot and during the day most people never notice it.
HemiPower36
CA
2014 Ram 1500 Laramie 4x4 3.92 8-speed
I really like how that looks. I gotta get me some Rigid ignites and do the same! Thanks for sharing.
Nick@GotExhaust
Preferred Vendor
SC
Nice work and great mod! I like the stealthy style install of these.
blackbetty14
CT
Hemi 5.7 VVT/Etorque
Looks great! Rigid $hit is no joke. Cutting that hole musta sucked lol.
Ramit355
Minford Ohio
2019 Ram Laramie Sport 4WD
I put LED bulbs in the cargo lights up on the cab. When I back up in the dark and turn the cargo lights on I can see behind quite a distance and very bright!
