holly preformance intakes
jbmobbs
jbmobbs
murfreesboro, tennessee
lol dont worry about 1999blkdakrt i am building the truck i know what i bought i installed it and i drive it every day lol i know exactly what im tlkin about :D
jbmobbs
jbmobbs
lol yea it took me about 5 to 6k to get it this good of mpgs but i built the whole motor and tranny this trucks body has 96 thousand miles on it but the engine/tranny has only about 15 to 20k lol
1999blkdakrt
Magnum 360
:word:Don't worry about me, I am not familiar with throttle bodies at all.
A true 50mm.
A true 68mm 4.7l
A couple 52mm cores.
96 and up non egr type of vacuum routing.
92-95 egr type of vacuum routing.
Notice the 2 holes for vacuum routing and the 2 smaller holes in the bore as well versus the one hole and the notching in the bore seal. These 2 TB's "breathe" differently through their vacuum routing.
Enlarging these vacuum holes does what?
Holley used several different spring rates depending on the year of the vehicle.
Appears from your pic to have some of the hourglass reduction left in it, at a true 50mm this reduction is gone. Does it still has the stock blade with the "11" stamped on it?
The Assassin
B-more careful, Murderland
Doesn't make you an expert. We're all here to learn, and to help the members. A little bit of modesty goes a long way.
WhiteExpress
Midland, TX
It really does look like someone took a stock TB, painted it blue, and sold it to you.
I see no difference btwn that and the stock unit on my '00 Ram.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
I don't see a difference either. Here is a Holly performance throttle body, 52mm
Badger
Bettendorf, IA
I can see where it says Holley on his tb. Looks to be an older model though.
1999blkdakrt
Magnum 360
Holley tb's were stamped holley from 92-96. Until borg warner bought them. 97 tb's usually have a block stamped where it said holley. After that until 2003 none said holley. Unsure if Chrysler wanted to pay BW for the holley name any more or what.
Badger
Bettendorf, IA
So your saying since I have a 96 my stock tb should say Holley?
1999blkdakrt
Magnum 360
Yes your 1996 should say holley on the top of it. Yours should have a 95 casting mark on it. They were generally cast the prior year. Seems to be what I have seen since I started playing with them.
1999blkdakrt
Magnum 360
It will say holley but nevertheless Chrysler did not outsource them elsewhere. Once BW acquired holley I'm guessing chrysler wanted to save a few pennies and opted to leave the holley stamp off them. Still technically a holley TB made in the holley factory. Just under the BW umbrella.
jbmobbs
jbmobbs
this is true but when i pulled off my old one i compared them and they are different lol idk what the bigger vacume ports would do. do you? and the barrells are a little bit bigger than my old one....and no i donot think it has the 11 stamped on the blades.......i really do like that silver and red throttlebody it looks badd ass it maken me wanna get it
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Its a 52mm and it might go good with your engine mods.
1999blkdakrt
Magnum 360
That is a 400 dollar piece of billet!!
It has been know to whistle, if a person is willing to spend that much F&B offers a larger range of throttle bodies and they have corrected the whistle. They also continue to do R&D to improve on their existing design.
Here is a true 52mm of mine.
Ftank
