Just tell it like u would tell your friend... "Dude, I put bigger wheels on you". In all seriousness, I don't think you can on the newer Rams. If there's a way, I don't know it. But as far as I know, just try to compensate a little on the speedo2017 express. came with 17's, have 20's to put on. do i need to tell the truck? how?
Yes that's why I said I don't think there's a solid way to do it without buying a whole tuner or OBDwebsites say tranny and abs as well as speedo affected. i want to find the guy who said technology is going to make our lives easier and kill him.
Alpha works, but Rough Country makes a Speedometer corrector as well, and it can read codes.
https://www.roughcountry.com/speedometer-calibrator-90019.html
All of the tools do the exact same thing- adjust the tire size to correct the speedometer. It’s just that AlfaOBD is cheaper and capable of far more features than the one trick pony programmers.Alpha works, but Rough Country makes a Speedometer corrector as well, and it can read codes.
Possibly, I was just offering options.All of the tools do the exact same thing- adjust the tire size to correct the speedometer. It’s just that AlfaOBD is cheaper and capable of far more features than the one trick pony programmers.
AlphaOBD works great on the Rams for changing many parameters...Just tell it like u would tell your friend... "Dude, I put bigger wheels on you". In all seriousness, I don't think you can on the newer Rams. If there's a way, I don't know it. But as far as I know, just try to compensate a little on the speedo
Sent from my SM-N975U1 using Tapatalk
