gdawg55
Yes it will. I used one on my 2015, worked perfectly. Just plugs into OBII port
Took maybe 10-15 minutes driving, key on, key off, etc
Cool....thanks.
2017 express. came with 17's, have 20's to put on. do i need to tell the truck? how?
Use something like https://tiresize.com/calculator/ to figure out if you need to do anything at all in the first place based on entering both tire/wheel sizes.
Is the tire diameter the same ?? If it is you do not need to do anything. Otherwise find someone with a programmer that fits into the OBDII port and you can tell the truck computer what new tire size you have. Easy....Just tell it like u would tell your friend... "Dude, I put bigger wheels on you". In all seriousness, I don't think you can on the newer Rams. If there's a way, I don't know it. But as far as I know, just try to compensate a little on the speedo
Sent from my SM-N975U1 using Tapatalk
No on all counts. Taller tires turn fewer revolutions per mile traveled so if you didn't correct the speedometer you would actually have less miles not more. That being said when I did it I bought a used Hypertech Speedometer Recalibrator off of eBay for less than $100 to correct mine three years ago.What about the odometer? Do bigger tires affect the miles racked up on it making the truck resale worse?
