How many miles on your 4th gen, & what repairs, if any?
zogg
Southern Illinois
2018 Ram Express Quad Cab
Im just wondering how our Rams will hold up. For example, my son has a 2010 GMC with 106,000 miles and never had it in the shop for anything. My last F150 has 132,000, and I only changed a waterpump and front wheel bearings...
My 2015 Ram only has 3800 miles on it but so far it is flawless....as i would certainly expect.
Anyway, how about listing yor year, miles, and total repairs ......:favorites13:
ExpressRules
Southern New Jersey
2014 Express Crew Cab & 2019 Big Horn Crew Cab
2014 -- 31,000 miles ---- one recall
baum
savage, mn
2015 Laramie
my old '13 when i got rid of it with 28k miles none besides a radio software update and the rocker panel damage i caused) my '15 with 6k miles none yet
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
2012: 39K miles. One recall, one exhaust header replaced under warranty.
chris1965
South Carolina
My old truck- no issues until 150k miles- radiator leak- I replaced the water pump and the thermostat with it. no other issues.
the new one- well- just drove 3000 miles in 2 month- nothing so far.
BigRed4x4
Mid Michigan
70,000 and never any trouble that I didn't cause on my own.
TapRackBang
14,619 miles as of this posting. Cruise control has gone out and since been replaced. My biggest issue is my CEL has been coming on since Oct 2015. The code comes back as P0456 which is a small evap leak. The dealer has looked at it 4 times and as of last week replaced the leak detection pump.
As of today the CEL has come back on and I am getting the same code (P0456). So it leads me to believe that the dealer did not fix the issue or they are incompetent. I just got off the phone with Ram Customer Care, my case is being sent over to a case manager and I should hear back in 1-2 business days lol. I am going by GMC on my way home to look at Sierras, I'm done with FCA.
Good Luck with your truck though.
R/T_Fire
Pleasant Grove
I can't remember if I posted or not but here goes
96k (yeah I know high miles
1. Ring and pinion failure - complete rebuild covered by Recall.
2. Front caliper piston cracked, cause unknown.. fixed after 2 sets of
powerstop calipers
3. Lifter Failure - All lifters/cam replace engine refinished all the way down to
the short block - all covered under warranty
4. Transmission 4th gear failure - Covered under warranty gets replace next
wed.
5. ABS system fault - Actual problem unknown... Guessing its due to worn
wheel bearings but not sure not sure when I'll install those
By The time I'm done with my warranty everything major will have been replaced or refurbished except the short block.
Statcher1
Kentucky
My 2012 has 27,200 miles. No problems at all. Other than the check engine light. Due to my long tubes. That will be remedied as soon as I can sell my Bullydog and buy a Trinity w/ Hemifever.
Ram82808
46k and nothing!
Bighorn 4 Life
Blue Springs Missouri
2010 1500 Big Horn 38k miles
Pinion nut recall - fixed then the pinion baring was going out. So they rebuilt my rear for 200.00
Ac recall - fixed
Rack and Pinion leaked. Was replaced under warranty
I bought it new in Dec 2009. I had it lifted a week after I bought it.
Hemi395
Cape Cod MA
2013 BigHorn, 18700 miles
- Cab was put on crooked, fixed under warranty
- Trailer brake menu wasn't available, dealer flashed under warranty
- Pump seal on 65RFE started leaking, fixed under warranty
- ESC/ABS Module recall
- Driver airbag recall
- Side airbag recall
Other than that its been a great truck
Buckeye2019
2018 Cummins
2015 1800 great miles I love to drive this truck but I hate to put the miles on it. I have a Pontiac g6 I drive back n forth to work
hankRam2015
2015 1500 with 13,500 nothing but like changes
tones2SS
MA
2016 Ram Sport 4x4, regular cab. Less than 1,400 miles on my awesome truck!
I've had her for only 3 months now. :favorites13:
Sportznut
2019 Laramie
24,000 miles on my 2014 Hemi 5.7 w/8 speed. CC.
One minor issue. The black plastic molding on the roof was not bonded very well and came partially loose. Also had some recalls that the dealer took care of without issue. Great truck for long trips.
Sent from my SM-N900V using Tapatalk
