How often do you use the parking brake?
Purplert
Never. Unless I'm parking on a hill or something.
averageguy
Belleville Mi
hemi
I would think to keep pressure off the trans when parking on an incline you would have to apply the brakes and hold them, then apply the parking brake without releasing the brake pedal, then release the brake pedal and put the truck in park. Is this what everyone does? Otherwise wouldn't the incline already create pressure on the trans when you put it in park, take your foot off the brake then apply the parking brake? I only use it in a manual on a hill(saw one roll in gear before) or when in neutral, or auto or manual on a boat ramp but I usually don't have to get out.
tones2SS
MA
I always use the parking brake when I park my truck or car.
Jared26
Always, and I put the trans in neutral to let the truck rest on the parking brake before I put it in park if I'm on an incline.
ODLEO
AR
I use the parking brake anytime I am getting out of the truck whether on a hill or not
DJKW905
:naughty: when im unsure of the little rollback or forth while parking in tight spots lol
kad
Hudson Valley, NY
5.7L HEMI
Only when I park on an incline.
-K
trip1027
I only use it when I need to leave it in reverse to use the light bar that is my solo reverse light for when I am hooking to a trailer.... definently won't use in the winter again when I first got truck they got frozen in place somehow
Rampaige
Only on steep inclines and boat ramps to reduce stress on the tranny
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
only when i park on a hill, incline or when the TT is hooked up, always.
tumulte
4.7L V8
I only use mine on inclines as well, but also when hooking up to a trailer. I'll back up to where I need to be and then hit the brake so I don't get that little roll that throws my positioning off.
Sent from my Pixel XL using Tapatalk
CrispyBacon
This is the correct procedure!
ShirtPants!
Always use it. Was advised many years ago by an automatic trans mechanic that it's not good to rely on the Park pawl inside the transmission exclusively. Maybe that component in the 8-speeds is "high speed, low drag" (super strong) compared to the older Mopar automatics, but regardless, I always engage the parking brake too.
I went to school to be a mechanic for a little bit and that is exactly why I use mine every time! I even tell people that I ride with to use their parking break when I see them not using it ha ha!
patchelect
Dalton, MA
What's a parking brake?
Only use mine on the rare occasions that I park on inclines on all my vehicles. Otherwise I forget it's there. I understand the reasons to use it and won't make an argument for or against using it. I just don't use mine most of the time.
AzRamLover
Every time before putting the granny in park. An old stick shift habit to keep any stress out of the tranny.
Foot on the regular brake
Shift to neutral
Set parking brake
Foot off the regular brake
The truck rolls slightly and is stopped by the parking brake
Foot on regular brake and shift to park
Engine off
lagerstout
Somerdale, NJ
HEMI 5.7
I always use mine. Don't want the truck rocking back and forth against the tranny parking prawl.
