HPTuner Ease of Use
Daniel12
Toronto
HEMI 5.7L
Hello,
I’m thinking about getting HPT for my 2017 Ram. Already bought a donor PCM a while back and it’s just sitting in my garage because I’ve been hesitant to pull the trigger on getting the HPT setup.
I was wondering how easy their software is to use with our trucks. As of right now, all I want to do is increase my idle RPM and lower my fan-enable set points for an E-Fan conversion. Is this something a normal person can do themselves or does it require getting an experienced tuner involved?
Thanks
CanRebel
Toronto
Hello,
Thanks
Both. But the options you mentioned are relatively easy. There are few video's around that show you exactly what to do.
No clue about the E-fan, maybe @Wild one has played with that, I haven't.
Be careful and always do backups before playing.
Brandon-w
Yukon
2015 Ram 1500
This is very easy to do. There's literally a section for the ect and idle. If you need pics I'd be willing to fire up the comp and show you.
D
Daniel12
Toronto
HEMI 5.7L
Nice! I will reach out when I get the MVPI in my hand with the unlocked PCM. Will look at making the purchase this week.
Thanks
Brandon-w
Yukon
2015 Ram 1500
Thanks
Sounds good. Also shop eBay sometimes you can get good deals on new hp tuners with credits.
diymirage
Check out our vendor section, there is at least one vendor there who uses HP tuners, and might be able to guide you along
CanRebel
Toronto
Didn't notice he was in Toronto. Think there are two dyno shops that do it. I purchased one from HP, just sent them my file.
D
Daniel12
Toronto
HEMI 5.7L
Any idea what the shops are called? Found 1 place on Google called Toronto ECU Tuning but based on their social media, it looks like they may be no longer in the business.
Also, would this work:
1. Get scrapyard donor PCM unlocked locally
2. Take stock read of original PCM in truck with HPT
3. Uninstalled original PCM and install unlocked donor PCM in the truck
4. Write stock read to the donor PCM via OBD2 and MPVI3
or do I need to clone it with special tools?
Thanks
diymirage
Thanks
Not sure.
What I did with my 2500 is buy a used PCM and send that one out to get reprogrammed
Once it came back I installed it and kept the stocker with the stock tune for backup, or as a spare
Swezey23
Austin, TX
I have an HP Tuner I used on my '17 RAM with 6 credits left over. I'm looking it sell it as I sold my RAM last year.
MPVI 2+
You won't find HP Tuners on eBay as it's a restricted item in the US due to "emissions" b.s.
Swezey23
Austin, TX
Hello,
Thanks
You can also adjust your throttle response while you're in there if you're feeling extra spicy. Much better than those pedal commanders
