How to 1.5" Steel TGC rear coil spring spacer install
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
I recently tried this but for whatever reason, I just didn't have enough slack in my brake line and I was only going to add a 1". I am going to take it to my local shop and see if they can get it done. I may have to have the hard line bent or even longer brake lines. Take a look. Majorly bummed.
R.L.K.
R.L.K.
Bristol , Tn.
Hmm , check out my OP , I Removed this to give me more room with the break line .
Nice jack by the way !
I now have the low profile HIGH lift Orange Daytona [emoji1303]ec83ed0d029aa1358ffbd7fc9c3128a9.jpg
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
Thanks I will take a look again. Could be a winner.
Cooter91
Vancouver, BC
WOW!! REALLY REALLY WELL WRITTEN! BRAVO FKN ZULU! Hahaha! Honestly though, I feel like I can do this on a weekday before dinner, the way you fully detailed the procedure. thanks again.
R.L.K.
R.L.K.
Bristol , Tn.
If your talking about my original post. , Thanks brother I appreciate it. . I try to be over informative because everyone has different past experiences [emoji1303][emoji1303]
Mark De Souza
North Kingstown, RI
R.L.K., I second ****** 91!! Original post is AWESOME!!! I'm definitely doing these on my own! May let the shop do the Bils though...
R.L.K.
R.L.K.
Bristol , Tn.
Do the Bills yourself if your capable [emoji106]
I say this mainly because " professional" shops jack up this install more than diyers .
Diyers like most folks here are on forums and read the doos and don't so to speak .
Professional guys do this type work WRONG all day every day untill someone informs them of what they are doing improperly .....
Hemi395
Cape Cod MA
First off, thank you @R.L.K. for another great how-to thread! Just installed my TGC 1.5" spacers after putting Bilstein 5100s on at 2.8. I really didn't want the stiffer ride that most heavy duty replacement springs give you and I wanted a bit of rake back since I have a camper I tow several times a year. I also have Airlift 1000s which I was able to keep with the spacers because the spacers do have a hole in the center. I also sprayed some Fluid Film on the frame spring mount where the spacer sits as well as the spring mount on the axle.
The truck rides exactly like it did before and has the stance that a 4wd truck should have.12a1fc0b643be06ced16207d823cc9f7.jpg581a2904becc2afac73a32c698a96158.jpg481be589d485d8098160b8556368073d.jpg11aeef3fe9efc16fd05d2270a94064fc.jpg420e83563f8e5221fa1901e7f9439842.jpg732bc22549b3432f0e3a8574f505c606.jpg5eba3292c144c9c94250f5085e35219a.jpg81e019f0841436b348d1843d0f3670b2.jpg832e3b9c5c499150c6b1b8591a0c8d03.jpg
R.L.K.
R.L.K.
Bristol , Tn.
Awesome !!!
Glad I could help Hemi !
Great idea on the fluid film while the coils were off , and glad you could reuse the airlift 1k bags as well [emoji106][emoji106]
R.L.K.
R.L.K.
Bristol , Tn.
@Hemi395 , I thought you put an aftermarket muffler on your truck ? b0ce1712140afc93694e71bdc503f2cf.jpg
hodge-xj
5.9 cummins
So I know this is an old thread but those measurements you posted were on stock 275 60 20s after initial install?
R.L.K.
R.L.K.
Bristol , Tn.
Yes sir , my truck has bills up front at +2.8" and the steel TGC 1.5" Spacers on the back all on stock tires [emoji1360]
R.L.K.
R.L.K.
Bristol , Tn.
Bump[emoji16][emoji16]
R.L.K.
R.L.K.
Bristol , Tn.
GREAT POST!!!! I followed the instruction and was in and out of the bay in under 45 min.
Glad I could help Sir [emoji106]
Ram7081
HEMI 5.7
I see coil spacer that go on top of rear coil and ones that go on the bottom. What the difference?
Hemi395
Cape Cod MA
I wouldn't trust the ones that go on the bottom simply because there's no reliable way to make them lock in. The ones that are on the upper mounts lock in so well it's virtually impossible for it to come out....
Ram7081
HEMI 5.7
The bottom spacer sits on factory nipple (lack f a better word). The spacer has a nipple the coil now sits on.
Hemi395
Cape Cod MA
That one looks good[emoji106]
All the lower spacers I've seen literally sit on top and barely lock into the spring seat.
Ftank
