Ricks Ram
- May 1, 2015
- 4,411
- 3,388
- 2014
- Hemi 5.7
STecoD is the only guy I know the actually wired up the rear heated seats in his crew cab Tradesman. He doesn't have them up and running yet because we haven't put the sales code in it. There's a lot more wiring involved. You would need a center console that had the factory rear heated seat switches in the back and and if I'm not mistaken you would need a different harness depending on what your seats actually came out of. If you wanted to do a factory setup you would also need to add the sales code which you most likely could not do unless you have the AE tool. He will probably chime in and tell you what would be needed. In your case it would be much easier just to add aftermarket rear heated seats and wire them separately.Not trying to hijack Putz6x convo, but a question about adding REAR heated seats - they would have to be aftermarket heating pads, but I was wondering if there is a place that I could tap into power for them?
I know the Laramies can get heated rear seats but only in crew cabs (I have a Big Horn Quad cab) so Im just going under the assumption I have no wiring available to make it work. I dont mind using aftermarket pads and switches, just wasnt sure where to pull power from.
Thanks.
-Chris
Sent from my SCH-I545 using Tapatalk
