How To: Fogs on with the High Beams
Ricks Ram
Link to such a device? And does it work with 2018’s?
I don't have a link handy but the tool is made by a company called Auto Engenuity. It Is a scan tool that we have discovered can also change codes in the BCM. After you purchase the actual tool Plus the Chrysler interface it's going to run you around $400. I bought mine from KT perfomance. They had the best price I was able to find. Most of us bought tools to turn on several codes instead of just one so it made sense for us to purchase them. Obviously it would be a ridiculous amount of money to pay just to activate your fog lights with high beams. After a lot of trial and error we found the tool is good to turn on certain codes but other codes you activate can really mess up your BCM so you need to be careful when you use it. From what I am hearing the 2018 Rams have some type of security system in the BCM and it's much more difficult to try to activate codes that are not allowed. I have not tried to do anything on a 2018 Ram with my tool to have any first-hand knowledge to weather or not this is true.
Sent from my SCH-I545 using Tapatalk
IRSmart
I drink and I know things
Westminster, MD
2018 Power Wagon
6.4L Hemi
What codes would need to be turned on for fogs with high beams? Looking at my signature, I may or may not have access to a WiTech system and could turn mine on largely for free.
Ricks Ram
The AE tool shows the codes in a different format so I don't know what abbreviation code would show up on the WiTech. In many cases the dealer cannot turn on certain codes that Chrysler has not authorized with the WiTech as they are blocked out according to Vin#. That is why we bought the AE tool so we could turn on codes that Chrysler did not allow for our lower trim level trucks,heated,vented seats,heated steering wheel ect. If you have access to the tool you could always go in and look around but I highly doubt you'd be able to change that setting.
WilliamS
Tampa FL
Where are you located, I’d bet for a beer or cherry coke someone can get it running for you.
SouthernGypsy
Arkansas
6.7L Cummins
There used to be a trick on some models where you literally just clipped one of the legs off of the Fog Lamp relay (you can look it up for TJ Model Jeep Wranglers and the same trick worked for the Rams of the same generation) and that stopped it from switching off when you swapped from low to high beams. Don't know if that works anymore or not but I drive a lot in rural areas with winding roads at night and just got a 2018 Laramie that I want to fix so the driving lamps will stay on with the high beams as well.
WilliamS
Tampa FL
My 2000 Ford Focus had a similar trick you remove the relay and insert a jumper wire between 2 terminals and you can control the fogs independent from the other lights.
Damion
2019 Sport
The ram fogs seem to be controlled by the bcm and not by means of a relay.
WilliamS
Tampa FL
Coerect, and the AE tool can change it in less than a minute
Well more technical the bcm controls the relay but yes it’s still the bcm that tells them when they are allowed to function
DieselRamFan
Lake Havasu City
6.7L Cummins, 370hp 800 lb-ft
There is. On all 4th gens, turn your frog lights on with your low beams, snap the light controls on left hand side of wheel back towards yourself then all the way forward to the high beam position. Movement has to be fast and smooth and voila you've got los his and fogs at once. Headlight selector must be manually on and not in the auto position. Works like a charm.
Worked like a charm on my 2015 Ram Laramie Longhorn. Thanks And didn't cost me $800 for a programmer.
JoshR104
You can also program this with alphaobd if you already invested in it for other options.
I myself have programmed them to stay on with highs along with a bunch of other changes not bad for $50 app with a $50 bluetooth obd scan tool.
turkeybird56
Central Texas
Remember, diff laws for different states, ref Fogs on and how many lamps forward. In TX, only allowed a total of 4 lamps forward, just FYI
JB1
Houston, Texas
Same here, its amazing to read this thread and see what members used to do, now it's a simple command using alphaobd
Plainbroke
Kansas
Can you tell me the AlpahOBD settings I need to change for the Fogs to stay on with HiBeams?
Oh and Fog/Driving lights are illegal around waynoka oklahoma low beams or high beams... We had to find the fuse and pull it for the HP officer while down there. He was a jerk about it too.
nekkidhillbilly
hemi
its fog light drop out you can find most of this on youtube btw
