Pakkratt
I second what Deereguy says,. Mine took a few key cycles then it suddenly appeared.Thanks will give it a try in the AM
Mine had either no audio or at 1%+ was like being front row at a rock concert. I put it in late evening and then the next morning on the first start booted up and acted normally with sxm and the backup camera soft keys appearing.Funny thing there is no audio not even on regular radio and thru Bluetooth and aux
Sent from my iPad using Tapatalk Pro
Sounds like the system.has to be powered cycled a certain number of times or does a complete power down/discharge after a length of time, before on power up it queries the bcm and pulls the info fresh and everything appears.
you can still get the software updates, just not over the air. You will need a vin from the model year and type to plug into the fca site and download it to a usb.
I wish there was a way to activate the Sirius Guardian service kind of miss the send n go feature
I have a uas radio out of a 18 Ram 3500 installed in my 17 Ram 1500. I have had a issue with the audio will not change volume and a black screen for the radio function. I know there is a ota update but I cannot get the update. Does anyone have these files offline for download? The most recent version out is now 19.9
Actually the latest version 19.9 is only available OTA. I have not been able to download it and the TSB for its release says OTA only. The latest version I have been able to download is 18.14.
I installed the UAQ in my 14 Ram and there are some small glitches.
If you install the UAQ radio in your truck the Travel Link and Real-Time Traffic features will not work unless your truck originally came with that function because the code will not be set in your BCM. The Real-Time Traffic and Travel Link worked on the RA4 no matter what vehicle it was installed in as long as you had the subscription from XM. I activated the code with my tool and it worked perfectly but a lot of guys don't have this capability.
