Humor me for a minute...
ClassicJoe
NC
If I mount a universal winch mount/plate using only the two bottom bolts on the tow hooks, are those two bolts alone strong enough to hold up the plate/winch and are they strong enough to hold everything while using the winch?
I would assume since the hooks can be used to pull somebody out of a ditch, for example, it should be fine...
The only other issue I foresee is the universal mounts that I can find online do not seem like they will reach the bumper for the fairlead...
Yes, I know Vice makes a nice hidden winch mount, but they are out of my budget at the moment...
hunterdan
SE PA
2019 classic
I'd add a bracket that attaches to the front bumper mount to keep the tow hook mount from bending under load. The hidden winch kits attach to the tow hook mounts and to the front bumper mount.
crazykid1994
Remember the tow hook brackets that attach to the 2 lower bolts per side of the bumper mount too. 3 bolts per tow hook. I plan on doing the same when I build my winch cradle
ClassicJoe
ClassicJoe
NC
Yeah, I did not think about the two bolts in the front...
I was also looking at somehow mounting a hitch receiver to the piece of frame between the lower control arms then mounting a hitch mounted winch plate to that. That should put a fairlead pretty close to the bumper.
I feel like I am really just grasping at straws to make it work, but $569 for the Vice mount is just out of my budget at the moment.
I still do not understand why nobody has come out with another winch mount for our trucks...
caulk04
My guess is that most people just don't really need a winch. Even the ones who have one.
huntergreen
I like the idea of adding a front hitch. More attachment points to spread the weight over a larger area.
ClassicJoe
ClassicJoe
NC
What if I used the tow hook brackets that come with the Vice mount?
retired
montana
If $569 is out of your budget wait a while, as the cost of doing it wrong will exceed $569
bcbouy
pitt meadows/100 mile house
2021 power wagon
hemi
said every single person who needed a winch and didn't have one.you'd be surprised how much you use a winch for things other than pulling ones self out.
