I hate conflicting information (jack points)
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
The owner's manual says to use the axel tubes as jack points, the service manual clearly says not to use an axle tube.
CAUTION: Do not lift vehicle with a floor jack positioned
under:
An axle tube.
Anyone know about the discrepancy? I know people here have said they use the axle tubes. I wanted to get 4 scissor jacks and put them under the axles if the truck was going to sit for more than a couple weeks. Just get each tire off the ground and unloaded. Now I'm confused. I don't want to have to get 8 jacks (4 for the frame and 4 for the axles). I don't want to have to jack the frame up high enough to get the tires off the ground and leave the suspension unsupported.
zogg
Southern Illinois
2018 Ram Express Quad Cab
I always jack the rear with a jack under the center section and the front by the frame behind the bumper. Never had an issue
chopperman1
2018 Rebel
5.7L HEMI
Under the shock mounts on rear for sissor jack. You do not need however to jack it up for any extended period of time. That was from way back in bias ply tire days where they could flat spot. No longer a concern with properly inflated tires.
