i have 3rd gen that someone change the seats to leather and never hooked the wiring.
638kendallkendall
wis
5.9 l
now the state telling I have to have the air bags change. how do you tell what seats I have? they are gray with a ram head on the back. the truck is set up for heated seats. any ideas ?
Atlanta, GA
Take a picture of the interior of the truck. The 02-05 3rd gens have a different interior than the 06-08 ones. It sounds like you have the 06-08 leather seats if they’re all the same shade of grey. The 02-05 ones were a two tone grey/dark grey or black iirc.
If you have the correct seat for your year, then all the wiring should line up correctly for the airbags regardless of if they were originally not leather and then got switched. However, 06-07 had some weird wiring change mid year somewhere so they have two different shaped plugs under the drivers seats that may require you to either make a jumper between the two or simply change the connector from one to the other. I personally made a jumper when I added the factory heated seat option from 07 scrapped leather seats to my 06 cloth seats.
Do you currently have an SRS code being thrown on your dash...? Or maybe the little guy with the seat belt lighting up...?
Also, most if not all the 3rd gen trucks were included in the Takata airbag recall. If you have not gotten that issue resolved, then it would be worth a trip to the dealer to have them replace the airbags and possibly fix your state issue in the process.
If you give us a bit more info I’m sure we can figure it all out. I personally don’t like people driving around without working airbags. I’ve seen one too many nasty accidents that airbags didnt deploy in my line of work.
HemiLonestar
MD
Seat swap shouldn't matter to the airbag unless you have a regular cab. Early 3rd gen quad cabs don't have this issue at all. Pics will definitely help, specifically of your seats, your dash and also need to know if you have a reg cab or quad. A pic of the wiring you claim is unhooked would help also. Is the state telling you this because you have an airbag light on the dash or because of the recall?
Orca
