- Nov 2, 2020
- 10,151
- 12,801
- Location
- El Cajon Calif. 92021
- 2016
- 3.0 ecodiesel
The National Highway Traffic Safety Association sent this to me.
W58/NHTSA 20V-475
The Magnetic Material attached to the Tone wheel, provides a signal to the Crankshaft Position Sensor
If the material is lost, the engine loses its ability to synchronize injector pulses and cam timing.
The loss of crankshaft position can result in engine stall, as well as the loss the ability to restart the engine.
A loss of motive power can cause a vehicle to crash without prior warning.
FCA will repair the vehicle by reprogramming the PCM to maintain engine operation if the Magnetic Material is lost.
First thing i wonder about, is it only the Ecodiesel engines having this issue
It does not mention anything about replacing the Tone Wheel
I guess that is not a safety part of the fix
I think that the Tone Ring may be the same thing as an Reluctor Ring,
If it is, the ring is on the Crankshaft
I also wonder if this also happens in other years & they are sending this out to those other years in some kind of sequence
W58/NHTSA 20V-475
