i need help badly.
02blkram47
Lebanon, NH
2018 Ram 1500 Limited
I developed an exhaust leak where my Stock Y pipe meets my catalytic converter. Dealer tells me that the only way to get this Y pipe from Chrysler is to get the entire section that contains the cat which costs nearly $700. So my question is this
1. Can I just buy an aftermarket Y pipe like magnaflow and get this to fit with my cat?
2. Do I need to buy a new cat back system and cat with new Y pipe?
I was told that if I didn't want to pay for the stock Y and cat the dealer had a "guy" who would build me a new pipe with flange to connect to my cat for $440. That sounds crazy expensive to me.
I'm looking for the most simple solution? Any thoughts
I'm thinking about either an summit racing system or the American thunder system but what do I do with the cat and a leaky Y pipe?
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
You would be fine by just replacing the Y-pipe with a new Magnaflow. Adding a catback exhaust after that is going to make it sound great and add some power, but not necessary to get the leak fixed.
Do you know what size piping you have before and after the Y?
05singlecabHEMI
Lilburn,GA
Go to an exhaust shop and have him cut out like 1foot of pipe and have him put in a new peice. Id bet no more then $100
02blkram47
02blkram47
Lebanon, NH
So I have a flowmaster muffler with a turn down pipe. I put the turn down on myself and that was 2 5/8 so I'm assuming the muffler was a 2.5" outlet. I have no idea what is before the muffler but I do know its stock piping for a 4.7 L motor.
So any Y pipe will connect up to the cat? If that's the case I'd be happy to buy a new cat back and the Y pipe. So would this be 2.5" pipe all the way front to back?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
It is leaking right at where the pipe meets the cat? Any exhaust shop should be able to get you fixed up regaurdless
02blkram47
02blkram47
Lebanon, NH
I haven't crawled under there yet to see myself but the dealer said it was right where they meet. I think I have decided to buy an new Cat back system and get the Y pipe as well and just have an exhaust shop put it up and weld it all. Should be between $300-$350 total i would guess.
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
is your cat made right into the y like mine was? they are very expensive. if so, i would just redue the exhaust. new y pipe, new high flow cat, and pipe to connect the rest. like stated above, good exhaust shop could fix you right up. probabably cheaper with better performance.
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
heck, if its not that bad, they might even be able to just weld your old y up and fix it.
02blkram47
02blkram47
Lebanon, NH
Yes my Y is part of cat which is why they are like $700 from Chrysler. So now I'm wondering if I need a new Cat or can I just buy the Y along with a Cat back system? Only reason I'm asking is because now I have to replace my rear axle seal, left front cv axle, and the rack & pinion on top of needing a new exhaust system. I have never seen so many things go wrong at one time. All of this started because I hear a grinding noise when I take a right turn mostly when going up hill. They think it's the CV axle that has play in it ( I'm not convinced) the boot is still good no cracks or rips and I can turn just fine with no sloppiness. I'm thinking more to do with the rear seal maybe it's out of fluid completely or it part of bigger problem like a wheel bearing. I have no idea but I'm trying to figure out what to replace first and make it as cheap as possible. sorry for the rant
truckin151
2013 sport
The Magnaflow Y pipe doesnt replace that entire piece, only where they combine to creat the Y shape. But really, unless you cat is bad, just take it to any exhaust shop and have them run a new bead where the pipe meets the cat. If it costs more than $50 for the weld I'd be shocked
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
i cannt remember now but when i was looking at exhaust stuff i found that ypipe with the cat made into it for like 300$.
02blkram47
02blkram47
Lebanon, NH
That's still more than I'm willing to spend on a stock restricted exhaust. I'd rather spend that much or more and get a new free flowing system with new cat and Y pipe. I'll check out Summit racing and see what's available.
02blkram47
02blkram47
Lebanon, NH
I'll try this before looking for any new Y or cat. I'm still going to be looking a new cat back system though. Thanks for the input
02blkram47
02blkram47
Lebanon, NH
So I crawled under the truck this morning while it was running and it sounds like the exhaust leak is up at the flanges where this one piece cat and y pipe meet the headers I'm assuming. So now I need to get to the exhaust shop and see if repair is possible or if need to replace this pipe altogether.
02blkram47
02blkram47
Lebanon, NH
Well after driving home from the dealer today and feeling lighter in the wallet by $350 to have my CV axle changed my exhaust got even worse and is too bad to let go on. I broke down and ordered the magnaflow direct replacement catalytic converter with Y pipe combo from Advance auto parts for only $275 including a 20% coupon and free shipping. Hopefully when it gets here it will prove to be less restrictive and worth the money. In a few weeks ill replace the rest of the system.
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
cool. if you have alot of miles on your stock cat, you should feel a nice little improvement.
Goodie1990
