atc06jh
- Feb 23, 2013
- 573
- 320
- Location
- Middle Georgia
- 2014
- Hemi 5.7L
Can't hide money!
Yes. The old way of thinking was it was stronger. But tests and studies have shown that Z or 45 adds so much extra heat to the tempered frame it actually is detrimental.Interesting. Why vertical cuts and welds? Seems like most guys use either a 45* or zee cut when splicing frame rails.
You should box the frame.
It'll look like a Ford when bumps are hit.exactly what i said when i saw this in the 2nd gen what did you do today thread
Basically, do it right the first time.
So you box the frame...
Well sure. Since you are a journeyman welder that owns his own heavy truck shop and have been doing this type of thing for many years. Go ahead a box your frames. When you seize the frame from flexing and your trucks break in half, send them to me and I'll fix your boo boo.
So much has changed over the years. Even steel.Don;t you love it, when someone tells you, you are doing it wrong, when you have been doing it, longer than they have been alive?
Yes, new ideas and better ways to do things do pop up, constantly, but anyone, who does anything, professionally, will hear about long before some forum member points it out.
BTW, how weak are the frames, nowadays. Back in teh late 90's, used to have a limit to how far one could stretch Dodges, and they were known for buckling. Imagine FOrd even has issues with buckling, vs older frames.
just curious.
Have not kept up on this for last couple of decades.
Maybe... I know my truck is boxed/double, whatever you wanna call it - same damn thing unless you get technical. I know for a fact that when I get at angles or hit good sized bumps that I get 0 body roll.Are you confusing a double frame with boxing? High GVW, and high abuse applications may run a double(sometimes triple)frame, but they are "nested" C-Channel rails. Heavy truck stuff does NOT get boxed rails. Period.
Just cause I had too.
36" in the middle and 34" on the end.
Its a 2016 Quad cab 5500 Ram Cummins 4x4.
