in-line fuel filter
gsxr219
IN
I was having some hesitation with my 06 Ram 1500 with the 5.7 Hemi. Felt like the fuel delivery just wasnt right. I was going to change the fuel filter but couldnt find one. Any help here?
nim81
Fredericktown, MO
5.7L
I'm having same problem, not sure if it's fuel related. Check to make sure your throttle body is clean. That would be a good place to start.
Sent from my iPad using Tapatalk HD
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Fuel filter is in the tank I believe. not really changeable.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Welcome, A TB cleaning on these trucks do a wonder sometimes, also plugs make a world of difference.
truckin151
2013 sport
Yep filter is in the tank and is suppose to be a non-serviceable (lifetime) filter. Only way to really get to it is to drop the tank.
HemiBabe
DFW
^^yeppers, the one thing that sucks... but I would also try the TB it's prolly filthy
WhiteExpress
Midland, TX
The filter is easily serviceable. Just drop the tank, pull the fuel pump and there ya go!
BTW it's like a $50 part from Mopar. and basically NEVER your problem.
Rent a fuel pressure tester, hook it up, tape it to your windshield, and go for a cruise. Watch the pressure.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Just had my tank down and the "filter" looks like a tea bag and I am sure fuel pump would go bad before the you would ever need to change it as far as I have heard.
$miley
gas or diesel
emi 5.7
if performance issues are due to low fuel pressure you have codes set and "MIL" light on, p0087 low system fuel pressure and/or p0089 faulty pressure regulater, if this is not the case most likely throttle body requires inspection and cleaning if sparkplugs are within limits.
gunner1374
In the 405!!!
HEMI 5.7
I would remove the bed before dropping the tank. Just my opinion. It saves a lot of time and headaches.
