INEZ hot rods UCA install pics
Ohninehemisport
Chicago
Due to only having a 2" drop upfront and not going lower anytime soon I just purchased the UCA from Inez for alignment purposes. I adjusted them to be 3/8" longer than the stock arms. With the factory arms the lower adjustment bolts were maxed out all the way. This brings the truck to alignment specs with a 2" drop but it's borderline maxed out. With a longer UCA the adjustment bolts on the LCA will have more room for adjustment. I also changed the ball joint. I didn't like the ball joint they came with. I went with MAS RD heavy duty ball joint. Looks to be better quality and I like the red dust boot.
picture.php
picture.php
picture.php
picture.php
Trapinator
Houston
How much did they charge for just the uppers..if you don't mind me asking.
Quicksilver337
South FL
2016 Ram R/T
I like those MAS RD ball joints... are they a direct fit for Ram? part number? reason I ask is also have the Inez control arms
TIA
O
Ohninehemisport
Chicago
TIA
The INEZ control arms actually use chevy ball joints for both upper and lowers. Upper is part 6292
The MAS have a nice anti-corrosion coating. And a sealed dust boot.
Dubstep Shep
Houston
2014 R/T
Just a thought here, but wouldn't it make more sense to have the ball joint bolted in from the other side? It would produce less upper control arm angle.
ryan russell
Springdale Pa
That would put a lot of stress on the bolts instead.. I'd feel unsafe with it that way
The upper ball joint isn't a load carrying ball joint,it's basically along for the ride and to keep the spindle from falling over. Lower ball joint is another story though,lol
circuitguy
Elk Grove, CA
2017 Ram Tradesman Regular Cab
5.7L HEMI
Where did you get the ball joints from? Are they online?
circuitguy
Elk Grove, CA
5.7L HEMI
I have a pair on IHC upper control arms I will sell if anyone needs a pair, still new never installed.
hdoggie24
Huntington Beach CA
I'm lowered 2" with the belltech springs would adding those help me out. I do want to lower the front 1 more inch for a 3" front drop. Most say just cut the front spring half a coil to lower a bit more. I'm not wanting to buy the Inez 4/6 drop for just going another inch lower.
Orca
