I just purchased my first 2nd gen Ram - a 1997 2500 with a 5.8 Magnum, ext. cab with the Laramie SLT trim.
I'm starting to poke around more, and the more I do the stranger things I find. (Missing sound insulation for manual shifter, driver side reverse light now working despite having a good bulb, trip computer not working, radio issues listed below).
For starters, it appears to have the Infinity sound system, but has a standard OEM CD/Cassette/Radio. The FM works occasionally, if I'm on a hill with a clean line of site to the FM tower, otherwise nothing but static.
So, onto my question - should this setup even work? My understanding is that the factory Infinity system has a different wiring harness than a stock with a CD player. Does it have a different antenna connection? Could this be my problem with FM?
I have no problems ripping a dash apart, but I would like to get some working theories on what to look for before going into it blind.
I'll have to dig out a CD player and/or a cassette to test the other functions, but since I do have audio when I can see the tower - I have to assume the speakers are hooked up correctly.
Thanks in advance!
Thanks in advance!
