- Jan 8, 2015
- 9,103
- 4,794
- Location
- St. Louis
- 2014
- 3.6 Pentastar
YesWill a VP3 from a 2016 plug and play in my truck?
Hello Friends to the USA from Germany,
i have a 2016 Challenger SRT and i will update the U Connect
Software 16.09.09
Part Nummer: 68258397AF
Serial Nummer: T00BE117671883
I download the newest version at driveuconnect.com with the right VIN Number
Uconnect_VP4,18.45.01-My13-17
I put it on a USB with FAT32 - in the Challenger the screen shows me this messange:
Loader.lua: Model year mismatch. This software Update ist incompatible with this radio. Update cannot be perform..
I dont know why....can anybody help me ?
Greetings Marco
Here you go it is in the Uconnect8.4 directory under Panasonic (non USA Radios). They also have the 21.6 update which might have maps in it since it is over 9GB. I didn't download it since it is not for my US radio.
www.mydrive.ch.
username: mygig@soxag
Password: gasolio
Its a VP4 NA - CMC - 36670 J
I left the device original. It is not converted to the EU.
I look für 17.11 and 17.43 but the Files are destroyed after unpacking
You have this files and can upload it ?
How do you mean the files are destroyed after unpacking?
FYI, the 17.xx.xx files will be different from the earlier files. Instead of 1 or 2 files, there will be several. Same with the 18.xx.xx update.
Well, then you will need to go to a challenger forum and ask if anyone has the v17.x software update for a 2016 Challenger RA4/VP4-NA radio PN: 68258397AF
* The Ram radio's here use different hardware and sw updates than the Challenger's. I don't have the files you need, and it's not likely anyone on this forum does.
I believe it expands on the drive during install and also creates a recovery on the drive of your current firmware prior to flashing.Why does SB 0801619 REV. D state that the flash drive needs to be at least 16 GB when the files are only 1.06GB when downloaded?
I did have one UAS with a factory flash of 22.6 that did the same thing. I wonder if it's a calibration thing? If you can get it to play a long notification try turning it all the way up and all the way down while the notification plays. Having CarPlay or Android Auto read the weather report may be a long enough notification.Here is an update for everyone. After installing the 22.6 software update on my UAQ tonight I am still experiencing the excessive volume when the Voice Recognition or Phone button on the steering wheel are pressed and when I receive a "new text message from" alert. I have tried several times to lower the volume when pressing either of those buttons or when a text massage comes through via Bluetooth but, the volume is still reverting back to the slightly obnoxious level 14. I will however say that the alert for a text massage sounds less clear now. It just sounds gritty is the best way I can explain it. I'm hoping that after the truck has had a chance to sleep for several hours the issues are resolved. I have not had a chance yet to see if the speakers still sound distorted at times as it's only occasional but didn't happen until I installed the UAQ. I purchased the UAQ brand new last year and previously had a RA4. My truck came factory with the RA2 and my previous software that came loaded on the radio was 22.5
17' CCSB 4X4 68RFE 2500 6.7 Tradesman DRP EGR delete, CTT tuning w/TCM tuning, UAQ w/7 speed HVAC, 7" premium EVIC, OEM front Parksense, OEM style front camera, aux switches, OEM remote start, Single Zone ATC
I hope it's not stuck like this lol. I'm about to pull the inline radio fuse in an hour or so then I will update everyone. I did try the volume all the way up and down during one notification like you suggested with no luck yet.I did have one UAS with a factory flash of 22.6 that did the same thing. I wonder if it's a calibration thing? If you can get it to play a long notification try turning it all the way up and all the way down while the notification plays. Having CarPlay or Android Auto read the weather report may be a long enough notification.
It's only reverting after shutting off the truck though right?I pulled the inline fuse, waited two minutes then put it back in and did a startup then shut it back off let it sleep and turned it back on. I know I got the correct fuse due to the Uconnect theme on the radio and the temporary loss of backup camera, cargo camera, and sxm softkey but, I have all of those back now. The notification & VR/phone volume is still reverting back to level 15 after lowering it[emoji2369]
