stimpy433
Can anyone help?
It still shows the same truck.
Can anyone help?
No word on this yet. Mine still shows a quad cab.
Vehicle Configuration set in the Body Computer:
Vehicle Config 1:
Body Style: 4-Door Pickup
should a 2016 7" evic cluster work in a 2014 express fully? maybe that's the issue i'm having with the turn-by-turn not displaying correctly. i also have a 2014 8.4an vp4.
Logic would dictate that it pick up the body style from the Body Style option in the BCM, not that all things on our trucks are logical...
Code:Vehicle Configuration set in the Body Computer: Vehicle Config 1: Body Style: 4-Door Pickup
-K
Yep it's really simple in my opinion .Anybody know how to take the lens and mask off, put on a new lens and mask on the 13+ premium IPC?
I can’t seem to find a write-up... or, I’m looking for the wrong thing.
Did you ever get the turn by turn figured out Sir ?should a 2016 7" evic cluster work in a 2014 express fully? maybe that's the issue i'm having with the turn-by-turn not displaying correctly. i also have a 2014 8.4an vp4.
I have a 14 Ram , a 16 cluster and an upgraded 15 RA4NA ..my truck was an original RA1 & and a 3.5" cluster .
Before I upgraded my Cluster my Nav Showed up in my smaller cluster with a directional turn arrow , street name and distance ..now like yours only street name and distance ?? No arrow indicating which way to turn ? Not a big deal as it shows up in the RA4 radio .
Just wondering if you were able to get the settings right or not .
maybe a related question, my sirius XM stations just show up as the station name, and a music note on the EVIC. is that normal, or is the station art supposed to display?
That's all I get as well. When I first put the cluster in I was assuming that it would display the track info for XM, USB and HD Radio, but if I'm reading the UConnect manual correctly, that whole "Audio" page on the cluster is pretty pointless. Just displays the source, that's it.
-K
does the "P" (park) flash on your cluster while in park?
Hmm.. I have a similar setup. My 2014 came with the 3.5" EVIC and an RA2 Radio. I replaced the EVIC with a 7" out of another '14 (not sure what, just a '14 RAm of some sort) a few months ago and I just replaced the RA2 with an RA4 out of a 2016 two days ago. After reading your posts I turned the turn-by-turn setting on and took it for a run, it seemed to work well, I got the turn images on the EVIC. So, that at least indicates that it's not an issue with '14 trucks.
-K
I don't recall it doing so, but I'll check this evening on the way home and let you know. I thought I recalled that meaning something specific though...
-K
Edit: I found this reference on the flashing P: https://www.ramforum.com/threads/p-in-gear-select-window-blinking-on-off-green.92445/
Letting it warn up to room temperature helps.Yep it's really simple in my opinion .
Place a small wedge such as a flat tip screwdriver between the white cluster and the black mask mounting tangs like this ...
Yes sir , I certainly would not try this in a shop / Garage when it's cold out . The plastic clips would likely break [emoji1303]Letting it warn up to room temperature helps.
That's a great idea !View attachment 147771
I used tile wedge shaped tile spacers when i took mine apart ($3 at home depot). Then just went around the edges with a flathead.
