Installing OEM backup cam
Discussion in 'Audio & Electronics' started by cptwing, Aug 17, 2014.
  1. Terryd
    Terryd Junior Member
    Jan 9, 2017
    Ram Year:
    Engine:
    1500 8.4a no navigation sorry new to the ram family it is an awesome truck...
    Mpgrimm2 likes this.
  2. Mpgrimm2
    Mpgrimm2 Preferred Vendor
    2,844
    1,515
    Mar 30, 2014
    GreenVille SC
    Ram Year:
    2013 SLT Crew
    Engine:
    3.6L V6 Pentastar
    See the links in post 10 referencing DannyMk2 and MTGTS and LoveRacing1988's for pictures of the 4 connectors. You will need to look under/inside the truck. It's possible to add the missing factory wiring, or you could just order the Mopar OEM camera kit which comes with everything you need and ignores any existing wiring.
    It's unlikely on your 1500 that you have full wiring in the truck.
    Sent from my non-flammable Galaxy S7!
    R.L.K. likes this.
  3. Mpgrimm2
    2,844
    1,515
    Mar 30, 2014
    GreenVille SC
    Ram Year:
    2013 SLT Crew
    Engine:
    3.6L V6 Pentastar
    Did you use the Lockpick, CustomTronix Jailbreak, or something else for the front camera add on?
    R.L.K. likes this.
  4. R.L.K.
    R.L.K. Supporting Member
    9,835
    5,606
    Dec 1, 2013
    Bristol , Tn.
    Ram Year:
    Engine:
    Wondering this myself .
    I'd like to add a front camera & a cargo cam in the future .
  5. R.L.K.
    9,835
    5,606
    Dec 1, 2013
    Bristol , Tn.
    Ram Year:
    Engine:
    http://www.ramforum.com/showthread.php?p=1434989
    Found this .
    Looks like he used CustomTronix
  6. jcarden10
    jcarden10 Senior Member
    162
    68
    Feb 17, 2016
    Raleigh, NC
    Ram Year:
    2014 Big Horn
    Engine:
    I installed the backup cam on my truck yesterday, but I don't have the active gridlines. I had to install the entire kit, so all of the wiring had to be done, including splicing the purple wire into the OR/DB wire at the BCM, but I am 99% sure the connection is good (I say 99% because it was my second time ever soldering; my first time was on the PDC wire, which I assume is a good connection because the camera works). I also purchased the AutoEnginuity scanner tool and activated the camera using that. The thing is, I don't have the Parkview options in the Safety settings through the radio, which is another reason I don't think the wiring is the problem, but I may be wrong. I know in Post 10 it says the older software may not show the lines, so I'm hoping this may be the problem, but I can't figure out how to check the software version. When I check for updates on the Uconnect website, it says no updates are available, so the software may be up to date.
    Any thoughts?
  7. R.L.K.
    9,835
    5,606
    Dec 1, 2013
    Bristol , Tn.
    Ram Year:
    Engine:
    What radio do you have Sir ?
    RA2 5.0"
  8. R.L.K.
    9,835
    5,606
    Dec 1, 2013
    Bristol , Tn.
    Ram Year:
    Engine:
    And if it's an RA2 did you upgrade from the RA1, or is it an original install ?
  9. R.L.K.
    9,835
    5,606
    Dec 1, 2013
    Bristol , Tn.
    Ram Year:
    Engine:
    When I upgraded my software , once you install the thumb drive into your USB port it shows your current software version , then gives you the option to install the new version .
    To my knowledge this is the only way to know what you have .
  10. Hemi395
    Hemi395 Senior Member
    36
    3,341
    2,695
    Mar 18, 2013
    Cape Cod MA
    Ram Year:
    Engine:
    In the settings there is a screen that gives you the software version. It's "System Information" on the RA3. Should be similar on the RA2...
Share This Page
